The F1 error means that water pressure into the washer is out of range...the control on the washer learns the water pressure coming in from when it was brand new it is capable of learning just the water pressure to your house since it will vary from your neighbors...after it has learned what the normal pressure is if it doesnt see that normal pressure coming into the washer it will throw up the F1 error code
What to check is if water is coming into the washer from the rubber fill hoses with as much pressure as always did...things that could cause lesser pressure is; kinked/crushed fill hose,sediment built up in the filter screens inside of the water inlet valve( can be checked by turning off water and removing hoses and pop screen out from the back of washer where the hoses connect to)
If the filter screens are clear and water seems to coming from the hoses with good pressure...the washer control board would need to be replaced
GENE
My washer keeps flashing f 32
Hello & Welcome to FixYa
F1 error in your whirlpool cabrio indicates bad
control and should be replaced to resolve the error code. However, you can
contact Whirlpool as well prior to replacing the control yourself as I have
seen whirlpool paying for the parts themselves just because this is known to be
a common issue. Please get back to me if you have any other questions.
Kevin
control board and should be replaced to resolve the error code. However, you can
Kevin
