Ricoh Aficio 2015 Copier Logo
Posted on Sep 06, 2011
The ir 3235 is displaying E000280 - 003 i want to know the cause of this fault
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 06, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
410
Points
Ricoh aficio 2105 error code 32836 the scanner is not working please help soon
Canon ir 3235 error code 225-0001
hi. that error indicates there is light deficiency in the contact image sensor (CIS) off the flat cable is defective or the CIS unit is defective
Error code E000225-0001
i have canon ir 3235 continueing error cord 225-0001
Canon ir 3235 error e000196
error in communication between laser driver and dc controller,check the wiring and connectors
2answers
Error code E000280-003 on Canon IR 3235
There is a error code in canon ir 3235 280-0003 what is the problem
1helpful
MY CANON IR 3235 HAS LOTS OF DUST IN IT HOW DO YOU CLEAN IT OR DOES IT REQUIRE A TECH?
if you have a toner vacum you can use it with no problem. If you don`t call a tech.
I accidently set user code on 3235 and can not shut off\r\nit blocks me from going into user tools
Are you taliking about Canon ir 3235?
SERVICE MODE:
* 2 8 * , select copier, function, clear, pwd-clr, and ok
Turn off/On
4helpful
2answers
How to clear code on ir 3235?
wich code?
E000, E001, E002 You can clear under service mode:
* 2 8 *
COPIER
FUNCTION
CLEAR
ERR
TURN OFF AND ON
Hope that helped
pls.rate
Top Ricoh Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
