It sounds like the box is working proper... just needs to wake up. the remote may be your problem.
God Bless Motorola For Giving Us Cable Boxes With No Buttons!
ok, does your remote have lights that flash when you hit buttons?
for example pushing volume lights up tv. if the cable light doesn't flash then it may need reprogrammed. if none of this applies to your remote... sorry
good luck
SOURCE: My DCT6200 cable box keeps
1) have you tried changing that box in that room to another and the box from the other to this room. That may give you an idea of either power or signal strength issue.
2) after it resets does a "dl" show up on the box front. if so it is trying to download a firmware/software update and everythime you power cycle it starts over.
3) turn the box off then hit select and go to option 8. there should be 4 modules enabled.
4) you may need a new box
