You can try to adjust with L screw. When starting a chainsaw it is best to put the screw to 1.5 turns from the end. Then set the idle. There are screw for minimum (the chain must be stationary at a minimum). H screw is for high revs. With H screw you can set the best work of chainsaw at high throttle. If you can not be set, it is necessary to clean the carburetor and check the nozzle membrane of a carburetor.
