Question about Kenmore 64802 Top Freezer Refrigerator
My refrigerator is leaking water inside down below the crisper. Is this a water flow issue and needs lines cleaned? Have to empty out every couple of weeks water under crisper. Kenmore model # 253-73079300
  • 2,341 Answers
That sound as if the defrost drain is blocked. This tip i wrote will help ya get to and check/clean the drain http://www.fixya.com/support/r9945686-check_when_refrig_cools_ok_but_leaks
GENE
Posted on Sep 05, 2011
6ya staff
SOURCE:
Water inside refrigerator
Because your model has an evaporator located inside the fresh food compartment it also will have a drain opening below that evaporator. This is a common problem with these dual evaporator models that have drain blockage caused by ice or gunk blocking the drain and causing water to flow below the crisper drawers. Sea Breeze
Nov 19, 2013 | Samsung RS275AC Refrigerator
Leaking Kenmore Refidgator
What is your model number? Sears Kenmore numbers look like this 321.2468102 I hear a lot of complaints from people that see water leaking into their refrigerator from seemingly nowhere. Water appears in different places and even inside or under a refrigerators that does not have a water or a ice dispenser! Frost free refrigerators defrost the ice that collects on the evaporator coil. Your refrigerator defrost on the average about every 8 hours so the water that accumulates during defrost has to go somewhere right? Yes the water is supposed to drain down a small drain line to a pan down near the compressor where warm air from the condenser fan will blow warm air over the water and evaporate the water again an put it back into the air inside your home, office or wherever your refrigerator is located. Over time that little drain tube gets slime, algae and a gooey white paste gunk that fills the drain line sides up stopping the waterflow downward to the condensate pan below refrigerator. If blocked by gunk or ice you will see trails of liquid leaking down the rear wall of fresh food compartment until it reaches the crisper drawers. Gunk is an accumulation of algae slime and just crud that appears from nowhere in a refrigerators defrost condensate drain line. How a refrigerator leaks is not always the same with every model as you may see frozen ice flowing down the rear wall of freezers on side by sides. Here is an example of a ET18PKXGTO Whirlpool refrigerator leaking water into a cup below the freezer compartment. Click here=> Whirlpool Leak Photo taken by TechnicianBrian. TechnicianBrian.com. And in this photo are several parts listed in photo group #1 were it is most likely running down the wall=> MagicChef CTB1921AR fresh food section. If you still have questions please ask and rate me if I was able to explain this well enough. Every refrigerator is made different so these are examples only. The key is to find if ice or just gunk has blocked you defrost drain. Unplug and then remove the rear panel in back of freezer. We need to see if the water is overflowing the condensate drain tray or if the blockage is in the turn the drain leads down back of your refrigerator. Much more on this page=> Leaking Refrigerators! If you run into any problems along the way of repair please let me know, Thanks, Sea Breeze
Jun 19, 2013 | Refrigerators
Water under crisper drawers
I am pretty sure you are having a defrost drain blockage problem. Most refrigerators defrost every eight hours and over a period of time the drain line that comes down from freezer into a cup like object top middle and back of the fresh food section (depending on the style refrigerator you have).Click Here=> Leaking Refrigerators Just What may Be Happening
I willbe here should you have questions, Thank You,
Sea Breeze
Feb 08, 2012 | Maytag Refrigerators
MTB2656G Top Freezer Refrigerator: Water is leaking and pooling below crispers in ref...
Clean the drain pan and drain line in the back of the freezer section underneath the evaporator coil. Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - make sure to put the tube exactly where it was.
Good luck! :)
Vlad
First Choice Appliance
May 06, 2010 | Maytag MTB2656G Top Freezer Refrigerator
Water leaking down into the crisper..thinking drain tube may be clogged any tips?
Every refrigerator will be just a little different, make sure yours is not leaning left or right. Most times the problem beginning just by a slow down or blockage in condensate drain line. The movie on this page makes it look simplw. Just remember all refrigerators are different and the rear panel in your freezer may need to be removed and as in photos on some cleaned out all the way to the drain pan below. Click Here=> WATER LEAKING FROM REFRIGERATOR OR INSIDE THE FREEZER OR FRESH FOOD SECTION
If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com
Thanks, Sea Breeze
Mar 15, 2010 | Refrigerators
Top freezer leaks water into lower fridge on our sears kenmore #70267990
The answer to finding the cause of the leak is where we need to begin. Most start in the freezer section behind the rear panel where the defrost condensate is drained during defrost. Sometimes the drain hole freezes over and the water drains down into the freezer creating a large area of frozen water. Other times i happens as the water leaves the drain in the freezer and follows its path to the pan below your refrigerator to re evaporate into the air inside your home. If leaking inside the fresh food compartment then the cup behind the control panel may be over flowing and leaking down the back wall of the refrigerator and will need to be taken apart and cleaned to allow the water to continue down to the pan below the refrigerator. Sludge and dust or even ice may be blocking this line. Below is a link to a page that may help you resolve and fix this. If you have more questions feel free to let me know. appliancepartsse@yahoo.com Thanks, Sea Breeze
click link below
HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
Aug 26, 2009 | Kenmore Refrigerators
My refrigerator keeps leaking water. Need help.
Hello, this sounds like you have a blockage in the drain tube, remove panel back of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Aug 25, 2009 | Sub-Zero Refrigerators
I have a roper RT21AKXGW00 refrigerator and water settles in the bottom of it and in the crisper draws, is this some sort of blockage?
I have the same model refrigerator and don't have a solution but I think I have more information on the problem. In mine, water will leak periodically from the condenser leading up to the freezer (inside the refrigerator, at the top, center, back of the main compartment). I have seen it leak and it isn't a constant leak but when it leaks it can pour out at a pretty high rate.
In mine, the water will collect in the deli drawer (near the top), the crisper drawers at the bottom, and under the crisper drawers. When it happens, I use a sponge to soak it up and wring into a bowl.
To minimize the impact, I have set up a cup or dish near the back of the fridge to catch the leak. I empty this every couple weeks or whenever it fills up, but I'm looking for more information on a fix (I think the problem has to do with the condenser - that's the lead I got when I found this post).
Aug 01, 2009 | Refrigerators
Refrigerator leaking water
This sounds like the water line from the icemaker and the cool water reservior inside the refridgerator side. The line is a rigid plastic hose and could be a leak at one point that is small enough to allow water to run along the line. Also sounds like you have a humidity problem. Check the door seals and wipe them off and apply a thin coat of die-electric grease to the seal. this will help keep it pliable and soft.
The water in the bottom leaks into a trough that is made into the fridge. This usaully evaporates, This is for the auto-defrost. It keeps the water from getting on the floor.
Check to see if the outer door gets hot at the edges. If not, It may not be auto-defrosting.
I would first check the water line first as this seems to be a more serious issue right now. The line is probably loose at one of the connections between the ice maker and water reservior.
Jun 14, 2009 | Maytag MSD2456G Side by Side Refrigerator
Water continuously running to fridge, overflowing?
Hi, if the only way you could stop the water was to turn it off at the water source, you need to change the water inlet valve. Make sure you check the water fill line for any leaks before you change the valve.
If I canassist you in getting the vavle, please let me know.
Thanks
Vic
Feb 18, 2009 | Whirlpool ET0WSRXML Top Freezer...
Kenmore 64802 Top Freezer Refrigerator Logo
445 people viewed this question
Top Kenmore Refrigerators Experts
Jimmy
geob91
John Tripp
John Tripp
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
