Send photos to [email protected]
Most coleman gens use the following part as assembly:
Part # 0062455 assembly , bridge rectifier
this assembly is installed on the plastic end cover and has a capacitor soldered onto the board. If this is the part that you have, then it is installed with the capacitor against the back plate. When it is installed, the back is the board is up facing you. The brush wires will only install one way because of the length of the wires (one will not reach to connect). If you are replacing parts on the board please send photo. Glad to help.
Thanks for sending photos, comment will follow.
After looking at photos. Looks nice and clean and the condition of the surface of the brushes look good (as the brushes wear, they will no longer make constant contact with the comm ring and begin to bounce /arc. When looking at the comm rings, they should look smooth. If dark spots are present, the brushes are bouncing (smooth with very fine paper) ). Verify that the brush closest to the bearing is the negative brush (the capacitor is marked with polarity, negative brush to negative cap). The capacitor should measure to within 95% of mfd rating to get full voltage output. The two yellow wires are AC output to power the magnet. Connect the two yellow to rectifier pins marked with AC or symbol of sine wave. Negative brush wire to rectifier marked with negative sign and positive brush wire to rectifer plus sign. Good luck with your repair
I emailed you pics as requested. Look forward to hearing from you.Thanks.
