My Epson Stylus CX4600 no longer prints any color other than black. Tried: cleaning heads, changing ink cartridges, even though it registered as having ink in the old ones.
When you change the ink cartridges you are NOT changing the print head. The print head is in the carrier. If the print head has become clogged or worn then usually it needs to be replaced. Unfortunately it us probably cheaper to buy a new printer.
If you're certain that it's not a clogged head then you could get a new head and snap it in yourself. You can try cleaning the contacts with an alcohol pad before forking out the $50 odd dollars it costs for a new head. There are also options in the various printer programs that set your printing jobs to monochrome, won't hurt to check that. Good luck
I can not print pictures in color from the internet o computer
If you're not able to print even after trying various options than you can take assistance from the technical support team or can contact third party tech support to check if there is any technical issue that can be resolved with expert technician. Enjoy high quality prints with Epson printers
SOURCE: My Epson Stylus NX 400 is not printing.
no it cannot. Those multi-colored cartridge system requires that you put in every single color, AND ensure that they are not empty before they will print. Even if all you want is a black and white copy.
SOURCE: Epson Stylus CX7400 Black ink won't print
You are a ******* and I WILL NEVER BUY A PIECE OF **** EPSON AGAIN...THESE PRINTERS ****
My grandma gave me her used Epson Stylus CX4600, but didn't print well. I bought new ink cartridges and installed them and it still only prints in black and white. I've cleaned the head several times and still nothing.
I have a officejet 600 printer with new ink packs that won't print in color only black.
hi my printer wont print in color i have a new color cartridge in but it still wont print. there is something eles that is clogged
Hp deskjet 845,After replacing the colour cartridge ;Black {15} print ok but colour {17} only prints red.
Cleaning the head
jamba
I have a brother mfc-5840cn and it will non print in yellow.
HP OfficeJet won't print color. Test page in B/W only.
i have a new hp deskjet f4235 it will only print in black in white no color........
cx4800
I have the same problem with my brand new HP Deskjet 4235 - will only print in black and white, but printer shows colored ink is full
the blank ink would not print but the colors can print
If this solution doesn't fix the problem, or you're printing a graph, you may have a printer that can override color printing. If your printer has this property:
Right-click the Start menu and select Settings.
Go to Devices and select Printers & Scanners on the left.
Select the name of your printer in the list and click Manage.
Choose Printer properties.
Check whether your printer has a noncolor option, and make sure that it isn't selected.
I hope these steps will be helpful!
Mark Wilson
