Question about Sony KS 50R200A Replacement Rear projection TV Lamp XL-5100 / 93087600
Lamp blew, picture went then sound also. Replaced lamp, now will not turn on. Red light flashing on front switch panel.
  • 10,594 Answers
If the red light flashing 3 times the pause and again flashing 3 times, check and make sure lamp cover is installed correctly back on tv.
Posted on Sep 05, 2011
6ya staff
SOURCE:
Picture went out - red light now on. Do I need a
Do ur LED light indication on the front screen panel "LAMP"Flashing?Yes,the lamp require changing.
Jun 06, 2010 | Mitsubishi WD-52627 52" Television
My lamp on my Mitsubishi WD65733 DLP TV actually blew up while I was watching it (kablooey). So, I bought a new lamp and replaced it. Now, the picture and sound comes on for about 30 seconds then it turns...
No check for bad capacitors on Power supply board they will be vented swollen or puffed up on top.
Go to Encompass Parts Distribution and look up your Model number.
May 09, 2010 | Mitsubishi WD-65733 65" HDTV
Lamp light on after i replaced the blown lamp Hitachi 60v500a
Was the tv working before you replaced the lamp? if it was then make shure you have reinstalled the new lamp and the door exactly as removed, there is a disconect switch on the door that has to close when the door is reinstalled,or sometimes the ballast may go bad at the same time.Hope tha t will help you fix it.
Mar 19, 2010 | Televison & Video
Replaced lamp TYLA1000
IF THE GREEN LIGHT IS FLASHING, THE LAMP COVER HAS NOT BEEN REPLACED PROPERLY. AFTER PUSHING IN THE LAMP SCREW IT DOWN THEN YOU ALSO HAVE TO REPLACE THE BLACK COVER AND SCREW IT IN AS WELL, I ASSUME IT IS BLACK ON ALL MODELS, THEN I REPLACED THE PANEL IN FRONT OF THE LAMP COVER. I DID THIS AND THE GREEN FLASHING LGTS WENT AWAY AND TV CAME BACK.
Jun 13, 2009 | Panasonic TY-LA1000 Projector Lamp for...
I have sound and no picture. Red light on in front of tv indicating lamp. Can be fixed w/o repairman?
Yes the Lamp can fail within that time frame. Much of it depends on how many hours the set is running. Most Lamps have a 3000 to 5000 hrs of life. But with any Halogen style Lamp, this is not written in stone.
Hope this helps,
Skyassoc
May 11, 2009 | Mitsubishi WD-65833 65" HDTV
Red power light and buzzing sound with red lamp light.
My Sony lost its picture and had a flashing light. Unplugging for 36 hours solved the problem.
Mar 29, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Tv black, no sound
is there any led or small lights on front panel ... red green or flashing
Aug 08, 2008 | Toshiba 46H84 46" Rear Projection...
Mits 62525
take the lamp back out and reset the lamp
Dec 27, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Sony KS 50R200A Replacement Rear projection TV Lamp XL-5100 / 93087600 Logo
405 people viewed this question
Top Sony Office Equipment & Supplies Experts
jasbo
jasbo
Eric Rotmil
Eric Rotmil
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
