SOURCE: ipod 2gb hanged
To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector)
If the above steps did not work, try
connecting iPod to a power adapter and plug the power adapter into an
electrical outlet, or connect iPod to your computer. Make sure the
computer is turned on and isn't set to go to sleep.
If you
are still unable to reset your iPod, use only one finger from one hand
to press the Center (Select) button, and one finger from the other hand
to press the Menu button.
When you reset iPod all your music
and files are saved, but some customized settings may be lost. Date and
time is preserved (unless the iPod reset itself because it had no power
and then was reconnected to power). Other customized settings, such as
Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth
are preserved from the last time the hard drive turned on.
To reset an iPod with a Click Wheel, including:
Tip: If you are having
difficulty resetting your iPod, set it on a flat surface. Make sure the
finger pressing the Select button is not touching any part of the click
wheel. Also make sure that you are pressing the Menu button toward the
outside of the click wheel, and not near the center.
If the above
steps did not work, try connecting iPod to a power adapter and plug the
power adapter into an electrical outlet, or connect iPod to your
computer. Make sure the computer is turned on and isn't set to go to
sleep.
