HTC Touch P3450 Smartphone Logo
Posted on Sep 05, 2011
Not working wlan - HTC Touch P3450 Smartphone
Anonymous
Level 1:
New Friend:
  • Contributor 15 Answers
  • Posted on Sep 05, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
15
Questions
0
Helped
1980
Points
44
You can contact the service provider........
My m105 works great but will not hold a wireless connection. Please advise....Allan...
Hello
Disable firewall settings to check if it doesn't block connection.
1) Update the WLan driver. In most cases this solves connections issues.
http://aps2.toshiba-tro.de/wlan/
2) Go to device manger -> WLan card -> Properties -> Advanced tab and check if the WLan modus 802.11 B/G or N has been set to the same Wlan modules supported by router!
3) Disable the WLan encryption and password on the router and check if you could connect to the router without any security settings. Do this only for testing purposes. If it connects properly, enable the encryption password and try again.
4) Disable WLan power saving! This can be done in Win Power Management. If that doesn't work, perform a system restore, set your computer to how it was the last time you were on the internet.
Hi i have a u135 and it hasbuilt in blue tooth but i donot know how to activate could u help
Not sure if this will work for your model but its worth a try. Copied from MSI support faq website
You have to press the WLAN button located right next to the power button in order to enable/disable the Bluetooth function. Press WLAN button once, Enable WLAN. Press WLAN button twice, Enable Bluetooth. Press WLAN button thrice, Enable both WLAN and Bluetooth. Press WLAN button four times, Disable both WLAN and Bluetooth.
8helpful
Cant get my wireless connection to work not sure
To enable/disable WLAN, please press "Fn+F11" to execute the device: (then follow below steps accordingly)
Note: there are four stages in all, assumingly both bluetooth and wifi are installed.
First stage : press Fn+F11 = Enable WLAN only
Second stage : press Fn+F11 = Bluetooth On + WLAN Off
Third stage press : Fn+F11 = Bluetooth On + WLAN On
Fourth stage press : Fn+F11 = Bluetooth Off + WLAN Off
After enabling the WLAN, search the Access Point and connect with it. Now, you may use the WLAN.
If this does not work, check if the driver is installed in your computer by going to the device manager. check under network adapters. If the driver is installed, uninstall the current driver and restart the computer.
If the issue still persists, you may download the driver update at the msi website: http://www.msi.com/index.php?func=nbdriver&maincat_no=135&prod_no=1474. Just make sure the driver you're downloading is compatible with yoru operating system
2helpful
I HAVE PSL2XL-01R007 MODEL LAPTOP OF TOSHIBA OF SATELLIYE L20..I HAVE WI FI DEVICE BUT I WANT ITS DRIVER.TELL ME HOW I GET IT?
I am not sure of the chipset of your wireless card as it differ from country to country. So I am giving you the link for all the three chipsets according to Operating system for your Notebook.
Intel Chipset :
Windows XP : http://support1.toshiba-tro.de/tools/updates/intel-wlan/wlan-intel-XP-32-13001071.zip
Windows Vista : http://support1.toshiba-tro.de/tools/updates/intel-wlan/proset-intel-v124300-vista32.zip
Windows 7 : http://support1.toshiba-tro.de/tools/updates/intel-wlan/wlan-intel-win7-32-13001071.zip
Atheros chipset :
Windows XP : http://support1.toshiba-tro.de/tools/updates/atheros-wlan/atheros-cutil-xp-800720.zip
Windows vista : http://support1.toshiba-tro.de/tools/updates/atheros-wlan/atheros-wlan-vista-7702880.zip
Windows 7 : http://support1.toshiba-tro.de/tools/updates/atheros-wlan/atheros-wlan-win7-8002250.zip
Realtek chipset :
Windows 2000/Xp/Vista : http://support1.toshiba-tro.de/tools/updates/realtek-wlan/realtek_wlan_20091005.zip
Windows 7 : http://support1.toshiba-tro.de/tools/updates/realtek-wlan/realtek_wlan_win7_20100104.zip
Check out which chipset works out for you.
My wireless wlan card wireless network controller stopped workg
TRY REINSTALLING THE WLAN DRIVER. OR CHECK THE INTERNAL ANTENA CABLES OF WLAN. IF IT NOT WORKS. THEN THE ONLY SOLUTION IS TO REPLACE IT WITH THE WLAN CARD.
DONT FORGET TO VOTE.
1helpful
My inspiron 1501 informed me that the WLAN IEEE 802.11 WAS MALFUNCTIONING.WHAT TO DO?
The WLAN may be faulty or the driver got corrupted.
Reinstall the WLAN driver and check the Device Manager to see it the WLAN is working and enabled, if it is then configure it to match your wireless router settings.
If this doesn't work the most likely the WLAN card is faulty.
To get a wireless connection again, purchase a PCMCIA wireless card and insert it into the PCMCAI slot, install the driver for this wireless card and configure it to match your wireless router settings.
Wireless light is off.
I am now on the same kind of computer and I used to have this problem- dell said it's a motherboard problem and they replaced it for free. Now it works just fine!
Wlan disconnected
I'll need more information to give you an effective answer. If your wlan was connecting just fine, and now you don't have a stable connection, it could be a range issue and you'll have to get closer to the access point.
If your wlan doesn't work at all, and won't get recognized by your computer you may need the latest drivers, in which case I'll need the model number of your wlan device.
If it works, finds your wireless connection but can't connect, try resetting your wireless router.
2helpful
Wifi not working
Your WiFi works only if your phone is in a WLAN network.Select Menu>Tools>WLAN Wizard.The phone will automatically search for availiable WLAN networks.Select the desired network.Click Options>Start Web browsing.The phone will automatically create an acces point and you can browse the internet.
Top HTC Computers & Internet Experts
Paul Carew
john h
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
