RCA HD50LPW175 50" HDTV Logo
Posted on Sep 12, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Thomson 27LCDB03B Hello Sir, Based on the following symptoms please suggest:- 1. No backlight and LCD dark. 2. Tune to TV station in TV mode, got sound and volume can control but no display. 3. Connect to PC & sound card, got sound, no display. 4. Opened back cover and measured for DC volt, 12V, +/- 16V & 5Vs all got. 5. Upon connecting the power adapter & switching ON, briefly the backlight comes ON then OFF. I guess this is normal since the 21" LCD TV i got (Thomson) also does the same upon powering ON the switch. Please request if you need further info. Thank you.
  • ram53my Sep 12, 2008
    Hei Jaime,
    The service manual does not seems to be the one for the 27LCDB03B model that I have. For instance there are 2 connectors J1 & J2 if I am not mistaken to the inverter board.Furthermore there are 2 fans connected to the main board.
    Please send me the correct manual. Thank you.
    Dear Jaime867,
    Try to obtain the Thomson 30LCDB03B service manual. The unit I have have 2 connectors from the PFC/DC+DC/AUDIO POWER BD to the inverter bd. Furthermore the disassembly/assembly procedures totally cannot be used for the 27" model.
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 3 Answers
  • Posted on Dec 03, 2009
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
Questions
Helped
1260
Points
5
What does the inverter board look like there is a little red llight on on the board inside the big box beneath where the power cord plugs in is that little red light suposed to be on all the time
Jaime Hernandez
Level 3:
  • Master 2,351 Answers
  • Posted on Sep 12, 2008
Jaime Hernandez
Master
Level 3:
Answers
2351
Questions
Helped
782873
Points
6681
If all the voltages measure normal, the failure could be in the LCD's inverter board. I've checked the schematic and it seems like the 16 volts could be a bit higher, check the electrolytic capacitors filtering the voltage for the inverter board.
Click here to download the service manual.
Good Luck.
Thomson 27lcdb03b picture upside down
I would suspect main board more than one you replaced--not likely to get help as Thompson is not known for that--possible firmware upgrade seems likely.
On every set I have seen with upside down/inverted or reversed screen etc it has been either a firmware issue or a main board.
5answers
Grundig LCD TV
try to resolder the pins of the chroma IC and some possible lose connections you can see in the PCB board...
How to tune thomson tv 14MG135
first is to get it from AV mode which suggests it is on one of the rear audio/video inputs.
If no source or Tv video button on remote look in the menu--once off the AV input it should be able to tune.
Direct hookup with cable or what?
Hello dear sir i have an old samsung labtop
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out, this is the most likely case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.lcdparts.net
While watching my 32 inch lcd hdtv the screen turned dark
Could be some bad caps in the power supply but also the inverter panel.
1helpful
2answers
Toshiba a200 laptop Have black screen even tho laptop has booted up, going by the usual sounds.Took battery out and used ac adapter, but same problem.Switched power off several times, left off over night...
You could have a defective screen - follow this to determine the fault.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
Check out www.lcdparts.net for parts, repair service and DIY info.
1helpful
Screen is half dark and whistles when battery is unplugged
You could have a defective screen, either a faulty inverteror a CCFL lamp - follow this to determine the fault.
MY THOMSON SCENIUM BOARD IS DAMAGED!!
CALL 01245392539 AND THE UK THOMSON SUPPLIER WILL BE ABLE TO TELL YOU IF IT IS STILL AVAILABLE
1helpful
Thomson 27" LCD TV 27LCDB03B
cannot be presise but at worse the lcd back light is failing or the supply to it . this is a job for a service engineer
1helpful
13answers
Lcd tv
blown capacitors on the inverter/ vga board
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
