Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Windows Photo Gallery or Picasa.
SOURCE: transferring pictures from my Kodak EasyShare digital camera to my computer
This error message means that the preferences in EasyShare software are set to save pictures to the CD-ROM drive or some drive other than your hard drive. To correct this, follow these steps: Start EasyShare software. Select Tools > Preferences. Select the Transfer tab. Below "Select the location on your hard disk where you want to copy transferred pictures," select Browse. Browse to the desired location on the hard drive where you want to transfer your pictures. The default location is: For Windows 98/Me Operating Systems: c:/My Documents/My Pictures/Kodak Pictures For Windows 2000/XP Operating Systems: c:/Documents and Settings/user name/My Documents/My Pictures/Kodak Pictures Select OK to return to Preferences, then click Apply and OK to save and close the Preferences. Reconnect the camera, and transfer the pictures.
SOURCE: Picture transfer kodak c813 problems
yeah, go to my computer, find your camera.
find the files. highlight them. CTRL + V to copy
Paste them into your computer (make a folder etc)
Open em with windows media or something.
If they still dont work on your computer:
Download a video converter for the files.
x
SOURCE: windows XP will not find my digital camera. it is
First download the necessary drivers for Windows, download here. After you've downloaded the drivers, press the red "Share" button on the camera, then plug it in.
SOURCE: kodak easyshare C813 screen
Hi, are you having issue on camera LCD screen that it will not show anything on the screen? Kodak Easyshare C813 has no feature to turn the LCD screen Off only Kodak Easyshare Z series and some M series that has a view finder that you can switch the LCD screen off and just use the view finder to save battery power.
You can refer to Kodak Easyshare Manual check this site http://www.kodak.com/global/en/service/publications/index.jhtml?pq-path=1398#otherDigitalCameras
For troubleshooting http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
SOURCE: kodak easyshare c813 cracked screen
Try to buy a new replacement form here: http://www.ownta.com/kodak-easyshare-c813-digital-camera-repairing-lcd-display-screen-replacement.html
Copy
pictures/videos:
Press
the Review button, then the Menu button.
Press
^ v to highlight Copy, then press OK.
Press
^ v to highlight an option.
Press
OK.
Hope that helps
David
