SOURCE: 2005 Panasonic LCD TV Model# TC-26LX20
I am also having problems with the same year and model number panasonic, it is at the repair shop now. I think it is a lemon tv. won't buy panasonics anymore. Tried all the fixes recommended by panasonic. It happens after the tv is on for longer than 1/2 hour. It happens with dvds and different hook ups. my samsung is fine on all the same connections.
SOURCE: No DTV on my 2006 Polaroid FLM-2632 model 2700?????
Try going into your menu and putting the input to Antenna, then reprogram, let me know!
SOURCE: My Panasonic tv displays only a thin blue horizontal line
This is vertical problem. The tv have a cold solder in vertical ic or ic is bad.
SOURCE: i am just looking for
There is not a listing - because every set will be different.
You need a calibration DVD to get the optimum settings.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
SOURCE: what is the remote code
turn tv on
on remote
1. hit tv
2. hold down setup till it blinks twice(tv button light)
3.then press 991 wait till it blinks (tv button light)
4.press channel up slowly until tv turns off
5. once it turns off hit setup again
6. press the tv then power button and then see if tv turns on if not then you just missed the code(repeat)
