Por favor necesito colaboración para encontrar los drivers de sonido y modem para mi equipo SG3211LA el cual tenia instalado Linux y como el Pc es para un niño lo cambie a XP puedo ver videos pero no funciona ni el audio, modem ni red
Did this solution help? Can I be of further assistance?
P.S. -You can rate this solution with one of four votes, if you feel your issue is resolved.
"FixYa!" - The solution provides great advice on how to solve the problem. (Positive Rating) "Helpful" - The solution provides useful leads that helps solve the problem. (Positive Rating) "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated. (Negative Rating) "Inappropriate" - The solution has absolutely nothing to do with the problem.(Negative Rating)
Te ayudo la soluccion?
Did this solution help? Can I be of further assistance? P.S. -You can rate this solution with one of four votes, if you feel your issue is resolved.
"FixYa!" - The solution provides great advice on how to solve the problem. (Positive Rating)"Helpful" - The solution provides useful leads that helps solve the problem. (Positive Rating)"Thanks for Trying" - The solution does not solve the problem but the effort is appreciated. (Negative Rating)"Inappropriate" - The solution has absolutely nothing to do with the problem.(Negative Rating)
You can't post conmments that contain an email address.
Hola ... Lo siento, mi espa?ol es malo. Pero, puedo ayudarle. La tarjeta de v?deo no es ning?n problema. Usted necesita decodificador de DVD ... Intervideo WinDVD tiene uno. Si usted tiene descodificador de DVD, entonces usted puede obtener los controladores para el v?deo aqu?:
ok necesitas bajar el driver directo desde la pagina GE 98650 y si es posible el software que viene con ella si es que perdistes el disco. Verifica si a camara es compatible con tu sistema operativo.. o si ya salio un update para ella que resuelva el problema.. Todo se resolvera bajando thel propio site de la camara las ultimas drivers y actualizaciones... Por favor dale a click que mi informacion te ayudo suerte o me avisas para darte otros pasos
por favor necesito que me ayuden con la instalación de la cámara web d-link c310 en mi laptop modelo Sony VAIO VGN-N350FE con Windows Vista, ya que me sale como que no es compatible, por favor indiquenme como descarlos?.
Lamentable, pero sin el modelo de la placa madre o la tarjeta de sonido, no puedo encontrar el driver derecho. Si usted usa XP o la Vista, usted puede usar el incorporado choferes de audio, o usted puede intentar ESTE driver. Esto debería trabajar.
¡Si usted encuentra que la solución/respuesta que proporcioné le condujo a, o resultó en fijar, por favor cierre el boleto con un FixYa! la posición conforme a mi solución. Yo estaría muy agradecido por su espectáculo de la apreciación.
para bajar el driver tendrías que proveer el modelo exacto de la placa de sonido, y si está integrada en el motherboard, proveer el modelo exacto del motherboard... los puedes encontrar en la caja de los mismos y si no la tienes, abre el gabinete y buscalo impreso en el mother o en la placa de sonido si esta es externa. Normalmente los modelos de motherboards están impresos con letras blancas y son similares a esto P4V8X-MX y en el caso de las placas de sonido SoundBlaster Live Value 5.1 o algo por el estilo, dependiendo la marca...
obten esa informacion y regresa para enviarte a donde bajar los drivers.
