That's a great question, friend!
From what you have described your Electrolux dryer is not locking or starting when you hit the start button. It sounds like a potential issue with your door latch or main control panel. If your door latch is not sensing the door is closed and locked it will not start your washer cycle. Also, if your control panel is not registering the door is closed it will not lock and start the cycle. I suggest you reach out to a professional for proper repairs to be completed. If you do not have a professional contact you can visit your manufacturer's website for additional assistance. I hope this is helpful information to you. -Matt
Hello Elizabeth P Cochran - Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. If the door does not open, then it sounds like the washer is possibly experiencing a communication problem with the control board, wiring failure or faulty door lock. Contact a professional to move forward accurately to properly diagnose/repair unit.
• The door is not firmly closed. (E40)
• The machine is not plugged in or there is no power
at the socket.
• The main fuse has blown.
• The type of fabric has not been selected by means of
the relevant selector dial.
• The Start/Pause button has not been depressed.
• The Delay Start option has been selected
Please checked those followings.I hope that helps.Thanks.
