Lands Phones Logo
Posted on Sep 04, 2011
I have a wireless phone device type GE IS2 1850-A SMS. Handset lost the connection between the mobile to device base.When I insert the code 0000 device tries to connect and finally informs me that There is no connection.Is there another solution?
Anonymous
Level 1:
New Friend:
  • Contributor 27 Answers
  • Posted on Sep 04, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
27
Questions
0
Helped
5154
Points
81
For this problem contact your mobile service provider....
Micromax master resetting code all
1.NormalReset - Dial *#7780#
If you dial this code in Nokia handset, it will restore system setting without missing phone memory data (videos, photos, songs).
2. .Deep Reset - Dial *#7370#
When this code isdialed in Nokia handset, it will wholly clean internal phone memory. Entire phone settings and profiles will be deleted, but there is no effect on memory card data.
Remarks -
For Nokia Symbian 60 V1 supported mobile handset (7650, 3650, 3600, 3620, 3660, N-Gage)
you can dial *#7780#*#7370#
Latest S60 mobile handsets, you can dial Deep Reset through another way.
*.Switch off mobile handset first.
*.Press calling key (green), 3 and * keys or (Green calling button + 3 + *)at same time and grip them down.
*.You find a message about format mobile and then release these keys.
*. Password of Reset factory setting code will be either 1234 or 12345.
Nokia X3-02 mobile Restorefactory -
*.Go to Nokia menu lists, browse these options one by one-
*.Menu --settings-- Menu--- Restore Factory Setting
*.Insert phone code 12345and wait few moments to complete restore process.
Nokia 5230, 5800, 5233 and similar mobile handset Restore factory settings, how ?
*.Browse phone menu lists,
*.Then, go to
Menu - Settings - Phone -- Phone mgmt Factory settings
*.Insert security code -12345
*.Without data lost of internal memory, Nokia handset returns in original modes.
Hard reset of Latest Nokiahandset through another code -
*.Switch off mobile handset.
*.press and holdGreen (calling) +Red (End call button) + Camerakeys at the same time along with switch on power of mobile handset.
*.Then mobile asks to insert phone security lock code , so insert12345.
Samsung Restore factory code
*.*2767*3855#
*.*7465625*638*00000000*00000000#
*.#7465625*638*00000000#
or
*.Remove SIM card from mobile handset
*.Once off and on handset
*.Type *2767*2878# to perform internal memory reset
*.Insert SIM card again in mobile.
Samsung Androidsupport handset restore factory code -
Type*#*#7780#*#* - To Factory Restore.
Micromax Restore factory code for all version with Android -
You can use any following below code one by one to perform restore factory of Micromax mobile:
*.1122
*.0000
*.1234
=*symphony> 1122
=*nokia >5071 or 0000
=*micromax> 1234
=*tecno > 1234 or 0000
=*samsung> 1234
=*apale i phone >5869
BACK2HOME
Information from:
http://peperonity.com/sites/a--a.secret.mobile.codes/47096442
Terry
What is the factory reset code?
You shouldn't need a code to reset the handset, but the base requires a PIN (Default PIN is "0000"). I have typed the instructions below, but here is a link to the online PDF: http://dl.owneriq.net/5/5d7cdc19-660a-8934-7d52-e5205df74c27.pdf
Handset:
  1. Menu -> Settings ->Handset -> Reset Handset
  2. OK - press the control key to confirm
  3. End Call Button - Long Press (Idle Status)
This will reset individual settings & changes made by you. It will not affect the directory, calls list, SMS lists, the handset registration to the base and stored pictures or ringer melodies.
Base:
  1. Menu -> Settings -> Base -> Base Reset
  2. Enter the system PIN (Default PIN "0000" or the PIN you created)
  3. OK - Press the control key to confirm
If you already changed the system PIN to one of your own you will need to contact the Siemens Hotline for "expert intervention" (their words, not mine).Online: http://www.gigaset.com/en_US/support/contact.htmlWarranty Number: 1-866-247-8758 / Toll FreeOpening Hours: Sun. 6 pm - Fri. 6 pm continuously (EST)
2answers
How can i lock our sms
you can lock your SMS using an application
here is the link
http://www.getjar.com/mobile/51268/app-lock/
i hope it helps!
6helpful
4answers
How to reset bluedio av890
Switch it off.
Press the on off switch for little long duration, till the Light glows steady/permanent (without blinking).
At this stage it can be connected to a device enabled with Blue tooth in "switched on" condition using the passcode "0000" (four times zero)
MUTHUPETCHI V ([email protected])
1helpful
How do you pair this device with a mobile phone ?
Hi simon,
To pair the bluetooth headset to your mobile , you have to make your headset in visible mode, to do this
  • Press and hold the power button of the headset for 10 seconds, you should see LED flashing in the headset..
  • Now search for the bluetooth device from your Handset..
  • You could see a speaker symbol in the searched devices in your handset...
  • Just select that device and when it asks for the pair code provide 0000 by default of refer you Bluetooth headset manual.... After this you should be getting connected to the headset
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Phone says OUT OF RANGE while on the base and won't work.
The handset has lost the link with the base. This link codes the handset to the base with a unique security code so others with the same phone cannot use your phone line.
If you changed the battery, try disconnecting the base telephone line and ac adapter for a while (1/2 hour or so if possible).
Remove the battery from the handset as well.
After 1/2 hour, install the battery in the handset, connect the telephone line and ac adapter to the base. Place the handset in the charging base and the link should be established. If not, the phone is defective.
[email protected]
2helpful
2answers
Voxtel infinity x1 cordless phone is locked
Please press on red cancell button for 2 seconds, the phone will unlock.
4helpful
22answers
Wireless data connection
hi!!!!!!!!!
try to configure out first the router!!!!
may be it has network password or security key
Sep 23, 2008 • Cell Phones
1helpful
3answers
E2125 model
You need to reconnect this phone with the "base". If more than one charger came with this set, only one of them is the base. This would be the one connected to the phone line.
Please place it back in the charger that is the base or home unit.
Brian
If you have lost your manual, I will provide an onlink link shortly!
Phone problem
At the corded base set go to link handset go to 1 press flash/programm you will be asked to waiting for registration with handset, then go to handset go link base there also click on yes and again on flash/programm button you will be connected
Top GE Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
