When i turn on the receiver, its stays on for a couple seconds and then turns off. i took out the fuses and its stays on, but emits no sound. what could that be?
If it stays on for 3 seconds then it probally is not the transformer. However it may very well be the power amp no way to tell untill we operate. Call Pro Line Music 215-736-8055
See if you can spot a pattern to the failures. I suspect that it is heat related. In the time that the unit ran all day, I suspect that the volume level was lower. Am I correct? If so, then either there are poor solder connections which are being effected by heat or there is a part that is defective. Are there any other symptoms or does the unit just shut off? If you attempt to turn it on, will it play for a while? If you can solder, look for solder connections that look grainy or have rings and resolder them.
Does it power back up after it shuts down, if it does power back up it is unlikely it is an internal fuse, you would need to replace the fuse if that was the issue, could be an amplifier overload, check the demand your speakers require in watts, and be sure the right ohm speakers are being used, many receiver will display "overload protection"and shut down, and some just un-power to prevent a electical short from occuring.
Wires are touching somewhere (speaker wires)... Usually, the wires neg. and positive wires running to one speaker are touching... The receiver automatically detects this and emergently powers off...
It is not a fuse problem, when a fuse is gone does not start at all. It is probably the final amp circuit, there is a faulty IC in there that overheats after few seconds and the unit goes off by itself.
well if your getting sound out of your surround speakers then the sub is busted, if your getting no sound at all then your speaker input's are either bad or out... i would test the speaker inputs...
