I'm sure the OP no longer needs to format their Clickfree C1 HD325 for use on Mac OS X, but I'll answer this question for anyone else who may need a solution.
Before you begin, there are a few things that you should know about Clickfree C1 and Mac OS X compatibility:
-Most Clickfree devices are compatible with Mac OS X 10.5 or higher, but there are some Clickfree C1 devices that aren't compatible with Mac OS X. If your Clickfree C1 was manufactured prior to 2009: your Clickfree C1 won't be compatible with Mac OS X.
-Take a look at the label located underneath the Clickfree C1: if you see WD08xxXM (WD08 is what's important here, you can ignore the rest of the numbers/letters that follow), your Clickfree won't be Mac OS X compatible.
-Formatting the Clickfree C1 using HFS+ will prevent any Windows operating system from detecting the Clickfree correctly. Try formatting the Clickfree in NTFS from a Windows computer for compatibility with both Mac OS X and Windows.
Pre-requisites:
-A Mac using OS X version 10.5 or better
-Administrator rights
Try the following steps to format your Clickfree C1 for use on a Mac (note that this will erase the contents on your Clickfree C1):
a. Using your keyboard, press the option key + command key + spacebar at the same time; a finder window will appear
b. In the search field located at the top-right of the window, type: Disk Utility
c. Finder will perform a search, and will display the Disk Utility application icon; double-click on the Disk Utility. The Disk Utility application will start
d. Plug your Clickfree into USB, wait a few moments for the application to recognize the Clickfree
e. Click on Clickfree Backup Media from the left side of the Disk Utility window
f. Select the Erase tab
g. Click on the Volume Format drop-down, select: "Mac OS Extended (Journaled)"
h. In the Name field, type: CF_Storage
i. Click on the "Erase" button.
j. Once the erasing is complete, close the application
k. Unplug your Clickfree from USB
l. Plug your Clickfree back into USB
Thanks for your email. The Western Digital WD Passport comes formatted for a PC, so it does require that you format the drive so that the Mac can recognize it. First, open Disk Utility with the drive connected and running. Then, choose the drive on the left side, then choose the Partition Tab. Change the Current Partition to one, or the number of partitions you would like, then click Options. Here you will change the Partition Map Scheme to GUID, then click OK. Then in the Format Menu drop down choose Mac OS Extended (Journaled), then click Apply and OK. Your drive will now be formatted for a Mac. To format the drive for cross-platform use, make sure that you have backed up all your data from the drive as formatting will destroy any data on the drive. First, connect the drive to your Mac, and open Disk Utility. Then select your drive on the left side of the window and choose the Partition Tab. Then change the Current Partition drop-down menu to 1 partition and click on the Options button. A new window will appear where you will choose Master Boot Record (MBR), then click OK. Then choose Free Space from the Format drop-down menu, click Apply, then OK. Your drive will now appear unformatted. Then choose the Erase tab, choose FAT32 as the Format, name your drive (you will be limited to 11 characters), and click Erase, then OK. Your drive will then appear on the desktop formatted for cross-platform use, and you can copy the data you need to move to your PC and then connect the drive to your PC. If formatting is not an option, the you can buy a program such as MacDrive that will allow your PC to read and write Mac OS files.
