SOURCE: Recorded programs in english come out in Spanish
Make sure your TV hasn't been set for SAP (you'll find it in the audio settings menu). Second audio programming is often used to carry alternate languages, and if it's turned on you won't know it until you watch a program where it's being used. There may be a single button labeled SAP on the remote. If so, it's easy to change the TV setting without realizing it.
SOURCE: av channel
unplug it for 5 or 10 minutes then plug it back in turn it back on run it thru the setup program
SOURCE: I lost the remote. how
you can buy a universal remote or on some tvs you can access the menu by either hitting the volume up and down buttons at the same time or it might be the channel buttons so i would try both.GOOD LUCK!!!!!!!
