SOURCE: chuck change
open the chuck fully and remove the scre inside by turning clockwise. insert allen short side in to the chuck & tighten
the chuck. hold the drill & hit the allen counter clockwise & do it again as needed.
SOURCE: Won't charge fully
If your warranty has expired, you're best off buying a new drill. Replacing batteries will quickly add up to the cost of a new drill.
I know they cost a lot more, but, if you want something that will last a lot longer, look at a Milwaukee, DeWalt, Makita, Bosch, Hitachi for your replacement. Milwaukee actually guarantees their LiIon batteries will last 1,000 charges or longer.
SOURCE: lost 18V AC adaptor- can I use one made for laptop with 18V output?
I don't know if I would try this or not. there could be a difference in the amps and usually a charger is designed to shut off or go to trickle when the battery is fully charged.
SOURCE: I cannot register my new 3/8 inch B&D electric drill as instructe
OK try going to Blacnanddeckercom and in the header you will find a link on the right hand side to register your new tool. Let me know if you need more assistance.
Testimonial: "This was not helpful at all. I went to the site you suggested and still could not register my new drill. You said to go to "Blacnanddeckercom"?"
SOURCE: I have a Black & Decker 18V cordless drill
Look at the three jaws in the chuck,if on is further out than the others the you need to tap ti back into place with a small punch and a hammer.If this does not work then you need to replace the chuck,remove the screw at the bottom of the chuck[where you put the bit],then you will need to to clamp vise grip on the chuck and with it pointed away from you hit the vise grips with a hammer with a sharp blow downward and it should come off.Hope this helps.
