Hi, getting spark with the sparkplug grounded is not a true indication that the coil is ok. It requires significantly more voltage to fire the plug when its under compression,(about 4000 volts) which is probably why it won't fire when you directly induce fuel. To test this get a sparkplug(any type will do) and break the earth electrode off, earth the plug as you did previously. If the spark will not jump this gap the coil is bad. Coil air gap should be 8 thou. If the spark does jump this gap the only other problem the saw could have is a very large air leak. Eg, main seal blown out on the crankshaft or a torn inlet manifold. Hope this helps, regards Phil.
Often the cause is a failed fuel pump diaphram. Rebuild the carb... kits about $20. The diaphram works from engine vacuum pulses. Also the little flap type check valves go bad... the ethanol in gas doesn't help this problem...
Ignition mod is set @.04", butI get good spark at the plug...Have fresh gas and oil mix...Did try putting small amount of gas oil mix in the chamber, but did not even get a pop...Have read reviews on this saw, and most are negative
Got your email....Carb may need rebuilding....I know the primer works, can see the gas flowing up the primer tube from the bulb, but even if I quirt fuel into the chamber and try to start the unit, it refuses to fire....New spark plug, and I have pulled the plug and grounded it against the motor while pulling the starter, and I am getting spark....Why wouldn't the gas that I squirted into the chamber at least "pop" and fire? By the way, brand new gas and 40:1 oil mix
