Looking for some help got my 98 cbr 600 f3 a week ago parked it at my grams it rained bike fell over neutral light wont come on and won't try to start with the kick stand down please help
KICK HARDER TRY PULL STARTING IT..IN SECOND GEAR..DOES IT HAVE ENOUGH COMPRESSION TO START?IT SHOULD START PULLING IT...START OFF WITH NO THROTTLE THAN IF NOT STARTING CRACK THE THROTTLE SO LIGHTLY AND SHE SHOULD FIRE OFF WHILE IN GEAR BEING PULLED OF COURSE BE CARE FUL NOT TO RUN INTO. WHO EVERS PULLING YOU..USE A LONG TOW ROPE..IF YOUR NOT A SEASONDED RIDER AND KNOW YOUR BIKE VERY WELL I WOULD NOT ATTEMPT THE PULL START...IF NOT CHECK YOUR COMPRESSION AND TIMING..MAJOR VACUUM LEAK MAYBE AT BASE GASKET..IS ENGINE SUCKING TO MUCH AIR? GOOD LUCK..
first drain the carby, then set your air mixture screw 2 turns out, from the fully turned in position. The starting proceedure is as follows, when the engine is COLD, turn on fuel, pull on the choke fully, and kick the engine over. DO NOT use any throttle, when the engine is cold, and the choke is on. Remember Choke on, NO throttle. When warm, no choke, and a little throttle when kicking.
