SOURCE: my spa leaks
Good luck, I'm in the process of chipping away at the foam 3 days so far, still have not found leak, Tried everything dyed water, but with the way they do the STUPID foam the water could be dripping 3ft away from leak... **** poor design and the can foam to fill it back up is gonna cost a small fortune,,
SOURCE: when you first plug your dreamaker spa in the
TURN THE BREAKER OFF FOR 20 SEC THEN TURN BACK ON AND FAST TURN ON ALL PUMP FOR 30 SEC THIS WILL BLEED ANY AIR TRAP INSIDE THE SPA
SOURCE: My dreamaker spa is leaking. The water level has
It is most likely the shaft seal on the pump itself. Costs about $115 to have replaced, labor included.
