SOURCE: No lights on control panel. Plug is powered.
Independent of the bucket switch, the control panel should light when the unit is plugged into a powered receptacle and the on/off switch is depressed. The problem is likely the 12 amp. fuse located inside of the unit.
SOURCE: M7DH45B2A Dehumidifier
The fall may have knocked out some wiring -- open the unit (remove back panel, then remove front by taking out screws inside) and see if any of the cables to the front panel or control board came out.
SOURCE: replacement fan motor for ebac homedry 880
Hi, If you are in new Zealand and your 880 model is the NZ 870 model, the fan motor can be got at Carrier Air Conditioning, part # SP-W3035766, for around $105.00.
Noel
SOURCE: It runs, the fan works in Hi and Lo, the
Take it to a metal scrap yard and turn it in the copper and buy a new one. Buy a different brand.
Sorry to be so blunt but dehumidifiers are very cheap and disposable not many people work on them. If this help please rate me and do a testimonial.
SOURCE: My Kenmore 580.54501 dehumidifier "Water Bucket
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
