SOURCE: Kitchen Aid Ice maker Stopped working
I would suggest not buying a KitchenAid. I have the same problem with my ice maker. Have had nothing but problems with every KitchenAid product that I have ever owned. I will never purchase another KitchenAid product.
All of there appliances are second rate. That is "The KitchenAid Difference"
The ice maker has stopped working. The red led light blinks when the freezer door is opened. Any thoughts?
SOURCE: NO WATER IN ICE MAKER
From what you've described, it sounds like you have a defective inlet water-valve.
I would remove your outside rear bottom panel; disconnect the 2 prong wires connected to your ice-maker water valve (blue with black solenoids) and check for continuity using an ohm-meter setting. If defective, replace. Whats' your model #?
