Samsung WEP200 Headset Logo
Posted on Sep 11, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Bluetooth After trying to sync bluetooth message reads "No bluetooth device found try again?" The bluetooth is on...fully charged...and I followed the booklet instructions.
  • tiffmarie Dec 04, 2008
    tried to connect 2 phones a samsung SGH-A727 AND a TMOBILE SIDEKICK LX both won't connect to the device
  • taranjeet199 May 10, 2009
    i can not connect my samsung wep200 bluetooth headset with my sony erricson p910i. can someone solve this problem?
Anonymous
Level 2:
Champion:
  • Expert 274 Answers
  • Posted on Sep 28, 2011
Anonymous
Expert
Level 2:
Champion:
Answers
274
Questions
0
Helped
121369
Points
332
Does your mobile's bluetooth is opened?
Sir, here are some bluetooth headsets on my website, please pay a visit to.thanks.
http://www.uoften.com/
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 29, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1063
Points
Can i connect sumsung wep 200 bluetooth to my sony ericsson handset
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Sep 27, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
17700
Points
I have a LG rumor phone from sprint and I am trying to program my bluetooth samsung WEP 200 and it is saying no bluetooth device found how do I set up the bluetooth I lost my instruction. The bluetooth was previously hooked up to the Razor phone
3answers
My Bluetooth is stop pairing with my ipad
To get help pairing a Bluetooth accessory-like a wireless keyboard-to your iOS device, try these steps:
1) On your iOS device, go to Settings > Bluetooth and make sure that Bluetooth is on. If you can't turn on Bluetooth or you see a spinning gear, restart your iPhone, iPad, or iPod touch. Then try to pair and connect it again.
2) Make sure that your Bluetooth accessory and iOS device are close to each other.
3) Turn your Bluetooth accessory off and back on again.
4) Make sure that your Bluetooth accessory is on and fully charged or connected to power. If your accessory uses batteries, see if they need to be replaced.
If you still can't pair or connect your Bluetooth accessory.
1) If you previously connected your Bluetooth accessory to your iOS device, unpair the accessory, put it back in discovery mode, then try to pair and connect it again.
2) If you can pair your accessory with some devices but not your iOS device, unpair the accessory from your other devices. Then try to pair with your iOS device again.
3) Check with the accessory manufacturer to make sure that your accessory supports your iOS device.
4) If you still have any of these issues, contact Apple Support:
You can't turn on Bluetooth or the setting is grayed out.
You can't connect any Bluetooth accessories with your device.
The accessory manufacturer confirmed that your accessory is working correctly.
The freeway does not respond to any phone commands
Be certain that your bluetooth is fully charged, then be certain you follow BOTH your phone's and your bluetooth devices instruction for pairing.
Exactly what phone commands are you trying to get your bluetooth device to respond to?
2answers
My headset will not turn on
Hello
Your bluetooth headset is powered by an internal battery. If the battery is not charged,it just won't turn on. Fully charge your battery before use.
Make sure that the power outlet you're using is working and that the cord is fitted correctly into the wall, PC or Car outlet and the Jabra Bluetooth device.
Try unplugging the Jabra Bluetooth device and see if it turns on. If so, use the Jabra Bluetooth device until the battery is completely exhausted. The next time you charge it, check that it is charging properly
If the Jabra Bluetooth device is still not charging, check what happens when you initially plug the Bluetooth device into its charger. If the light on the Bluetooth device flashes on and then off again quickly, it is likely that the battery is no longer working. Batteries cannot be replaced or covered warranty
14helpful
3answers
My nokia bh 213 bluetooth was working with nokia E63 , all of a sudden it is not , the bluetooth is charged and green light is flickering , when tried to pair thed eivce it says the device not found , what...
Thanks sleekycupid.. Even i had a same problem just followed the steps you said.
Step 1: Switch off the bluetooth device.
Step 2: Charge the bluetooth device.
Step 3: Then hold the device button till the green indicator blinks faster than normal.
Step 4: Now try to pair the device from your mobile.
Step 5: Mobile will ask you a passcode, press 0000 and enter.
You might not follow step 1 and 2. Just start from step 3.
Enjoy!
2helpful
Plantronics Explorer 220 bluetooth won't pair with LG NV3 phone. It's in discovery mode and I'm getting the red/blue flashing on the bluetooth like the manual says, but it just keeps searching and will not...
Well I got it working, of course, try turning the phone off on again instead of just the bluetooth, it worked. I should have done that before posting the question.
1helpful
2answers
Cannot register my bluetooth to my PS3 please help
did you try to hold down the power button on your headset until it blinks and then try to sync to the ps3 again. You have to put he headset into sync mode before attempting to put the ps3 into sync mode
1helpful
2answers
Bluetooth won't connect
follow the steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the Motorola device and click add
6) You will be required to enter in a pass code which is standard ‘0000’
7) If successful then the headset will start flashing BLUE every few seconds.
• The headset is now paired with the phone
Hope this helps
Season's Greetings from Fixya!
Chris (ziraffa)
24helpful
4answers
Plantronics Voyager 510 & Blackberry Curve
 Plantronics Support Phone Number: 1-800-544-4660
Do not use the power button to sync.
To sync device, Press + button (volume) and Silver button (on boom) at simultaneously. LED Light will blink RED & BLUE.  Device ID should appear on your screen.
Bluetooth problem
I have a motorizr z3 that I purchased a week ago. I cannot get the blue tooth to turn on. I ONCE got my Plantronics bluetooth synced but it would never turn on again, so I deleted it off, and now everytime I try and turn bluetooth on, I get a message of "Bluetooth Power Failed - try again later". It tells me the same thing when I try Setup or Find Me...any ideas how to get this to work?
4helpful
5answers
I have a problem with my bluetooth H500
You need to full charge both units first before to try them again. YOU MUST KNOW ONE MAIN KEY HERE IS THE BLUETOOTH HEADSET MUST BE IN PAIRING MODE WHICH IS MEAN THAT THE LED MUST IN STANDING MODE NOT IN FLASHING MODE AND WHEN THE LED OF THE BLUETOOTH HEADSET IS IN STANDING MODE, BRING IT CLOSER TO YOUR PHONE AND BE SURE YOUR PHONE BLUETOOTH FEATURE IS ON AND BE RECOGNIZED FROM OTHER DEVICES. Try to restart carefully step by step each device as described above and then if you still can not get them pairing then either on eof them has Bluetooth function impaired. You need to have another Bluetooth Headset to test whether your phone Bluetooth function or the Headset has it. Good Luck
Top Samsung Radio Communications Experts
ZJ Limited
ZJ Limited
Jean Thiebaux
Grand Canyon Tech
Grand Canyon Tech
Are you a Samsung Radio Communication Expert? Answer questions, earn points and help others
