Computers & Internet Logo
Philip Patterson Posted on Sep 02, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
IM RUNNING WINDOWS PROFESSIONAL ON AN OLD COMPUTER, AND I CAN GET PAST THE WINDOWS 2000 PRO LOGON SCREEN WHEN I START MY COMPUTER. HOW DO I RESET THE ADMINISTATORS LOGON?
Justin
Level 3:
  • Master 2,072 Answers
  • Posted on Sep 02, 2011
Justin
Master
Level 3:
Answers
2072
Questions
0
Helped
432147
Points
5629
tip
How to Recover Windows 2000 Password
Forgot administrator password on a system running Windows 2000 can be problematic when the administrator to perform maintenance. There is a trick that allows a computer user to reset his password, if you forgot. The process to recover a password in Windows 2003 and XP is different from the process used for Windows NT and Windows 2000.
Step 1. Insert the installation CD of Windows 2000 / DVD into the drive of the computer and then restart the computer.
Step 2. Select the destination directory for the alternative Windows operating system when the program asks you to do. This directory is not the same as the default installation of Windows. This is the computer is a dual-boot system.
Step 3. When the computer restarts, select the alternate Windows installation from the dual-boot menu.
Step 4. Find the logon.scr file. It should be located in the %systemroot%\System32 folder of the Windows folder.
Step 5. Rename logon.scr and move it into the C: folder of the hard drive. You can choose to move it to a different directory. The important thing is to remember where the file gets copied.
Step 6. Find cmd.exe and make a copy of it in the %systemroot%\System32 folder. Move this file to the C: folder of your hard drive.
Step 7. Right-click on the original cmd.exe file and select "Rename." Delete the cmd.exe text and replace it with logon.scr.
Step 8. Restart the computer and start Windows installation. Do not touch the computer until the start of the screensaver. Since the screen saver file, get the default is replaced with the file cmd.exe, then a command prompt instead of the screen saver.
Step 9. At this prompt type: net user administrator <password>
Step 10. Delete logon.scr from the %systemroot%\system32 folder.
Step 11. Issue the following commands from the command prompt:
copy c:\logon.scr c:\windows\%systemroot\system32
copy c:\cmd.exe c:\windows\%systemroot\system 32
Step 12. Restart the computer in the original. From here you can remove the additional installation if desired. If the administrator installation alternatives are on a different drive or partition to reformat the hard disk or partition is the easiest way to achieve this goal.
on Apr 26, 2010 • Computers & Internet
2answers
I forgot my password and i cant logon to my computer
Which Password? Bios Password? Hard Drive Password? Windows Welcome Screen User Logon Password?
Which Operating System? Windows XP? Windows Vista? Windows 7?
OK, if you are running Windows 7, Microsoft tightenedsecurity on it so you've got to have a password reset disk which 99% of thepeople who own laptops with windows 7 fail to do. It should be one of thefirst things you do when you buy the laptop. Otherwise, you're faced withreinstalling the Operating System or possibly doing a System Recovery.
If you're on Windows XP or Vista try this:
Turn off the computer, then hit the power button to turn it back on andimmediately start hitting the F8 key repeatedly until you see the Safe Modeoption. Select SAFE MODE and let the computer boot up. When it getsto the User Login screen it will show the Administrator userid and the useridfor which you forgot the password. Sign in as the Administrator (hopefullyyou didn't put a password on it and forgot it too). Once the desktopappears it will look different, the screen will be darker and the icons bigger,but this is normal for safe mode.
Click Start/Control Panel/User Accounts
When the User Accounts screen opens, click on the userid for which you forgotthe password. Select the option to REMOVE PASSWORD.
Reboot your machine.
How t master reset a toshiba satellite pro 420 cdt
Which Password? Bios Password? Hard Drive Password? Windows Welcom Screen User Logon Password?
4helpful
9answers
I have forgotten my password for my acer aspire one and i cannot get onto my brand new laptop! because of the windows 7 please help!
I recommend software Windows Password Seeker. Not only support XP/Vista/2000/NT, but also compatible with windows 7, it works perfectly to remove Windows login password. I wrote it to a USB flash drive. Booting up and clearing my password within 4 minutes. You can download it from:http://www.passwordseeker.com
My brother has bought an old pc which is running on windows xp professional 2002 service pack 3. hes security protection ran out by the time he got the pc, so had no protection when using it for the past...
You need to boot up with an xp pro cd
from there you can wipeout and reformat drive with windows
before you do that you need to get your xp key from the computer
any other way is just putting a band aid on it
2answers
Can't log on to the system at all
there is a reset butten inside the dell base unit towrds the front inside password reset
2answers
Restore windows 2000 like-new state
check if have backed up your system state before installing things on windows 2000. then you can restore the system state then delete all the program's folders by hand
XP Pro can't logon
try going to safe mode first,restart pc,press f8,go to safe mode..choose administrator..if that didnt work,install your windows xp,post a reply if that didnt work so i can tech you how to install your xp
1helpful
6answers
Pssword lock out
If you still can't find the solution try this thread: http://www.fixya.com/support/t156781-forgot_administrator_password
Grand Canyon Tech
Grand Canyon Tech
