SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
Posted on Sep 02, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Whta is difference between micro USB 2.0 and Micro USB 3.0 ?
Oaikhena Amaize
Level 2:
Scholar:
  • Expert 117 Answers
  • Posted on Sep 02, 2011
Oaikhena Amaize
Expert
Level 2:
Scholar:
Answers
117
Questions
0
Helped
26005
Points
369
Hello, the major difference is in speed. Usb 3.0 is super fast with speeds of 4.8Gbps compared to the 480mbps of usb 2.0. It also offers higher performance and better power management. Usb 3.0 devices have their own cables and such but are fully backward compatible with usb 2.0 but won't run at super speed in compatibility mode.
I hope this helps, thanks for using FixYa.
Brian Sullivan
Level 3:
  • SanDisk Master 27,725 Answers
Brian Sullivan
SanDisk Master
Level 3:
Answers
27725
Questions
Helped
5666252
Points
79191
Usb 3 is much faster than usb 2
Charging port loose.no longer charging on my tmax tablet
Try a different Micro-USB cable. It is usually caused by the cable's micro-USB end being loose and not the tablet's charging port. Most smartphones these days use Micro-USB so you can usually try using one of those if you have one.
My kindle will not charge
Use a different charger - se if any of the ones you have for your phones are Micro USB - they will charge it fine.
If not get a usb/micro usb cable or micro usb charger from most shops in the high street for 4 or 5 pounds.
If using the usb jack on a pc or laptop swap to a different usb jack on the pc or laptop
Kindle fire hd tablet won't charge up
1) Plug it into a different USB port on your pc;
2) Use a different USB charger - look to see if the one supplied with your 'phone has the common Micro USB jack;
Fire's take about 14-16 hours to charge from a pc and 3-5 from the wall,
1helpful
Sandisk ultra sdhc card won't record in my canon digital camera. i get a memory card error
All you have to do is
Step One
To save data, use EASEUS Data Recovery software (free version - 1GB of data recovery). how:
1. Download and install EASEUS Data Recovery
2. Insert micro SD
3. Open EASEUS Data Recovery, choose Complete Recovery - Next
4. Select the drive micro SD - Next
5. Save the data to the hard disk (max. 1GB)
6. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4, 5)
After all data is secure, do the process repair micro SD
Step Two
The first alternative - use the software HP Drive Key Boot Utility
Using the HP Drive Key Boot Utility, for Win XP
1. Download and install the software HP Drive Key Boot Utility
2. Then, double click the file cp006049.exe - select Install.
3. Insert micro SD
4. Then, open the program "HP Drive Key Boot Utility" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
5. Remove the micro SD from the USB port, then insert it again.
6. Quick format micro SD (FAT file system)
7. Restore all data, to the micro SD.
Using the HP Drive Key Boot Utility, for Win Vista or Seven
2. Then, double click the file cp006049.exe - select Extract
3. Insert micro SD
4. Then, double click file hpdkbu.exe - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
The second alternative - use software HDD Low Level Format Tool
1. Download and install HDD Low Level Format Tool
2. Insert micro SD
3. Open program HDD Low Level Format Tool, select micro SD - continue
4. Click S.M.A.R.T - click Get Smart Attributes
5. Click LOW LEVEL FORMAT - click Format this device
6. Wait until the process is complete - press OK
7. Remove the micro SD from the USB port, then insert it again.
8. Quick format micro SD (FAT file system)
9. Restore all data, to the micro SD.
I hope this information helps.
7helpful
2answers
I have locked my memory card and forgotten the password. Format card also requires password and my laptop cannot read it. Please help.
All you have to do is:
Step One:
2. Choose Complete Recovery - Next
3. Choose the drive micro SD - Next
4. Save the data to the hard disk (max. 1GB)
5. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4)
After all data is secure, do the process of removing the micro SD password
Step Two:
3. If you are using Win XP, double click the file cp006049.exe - select Install.
4. If you are using Win Vista or Seven, double click the file cp006049.exe - select extrack.
5. Then, open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Finish.
6. Remove the micro SD from the USB port, then insert it again.
7. Quick format micro SD (FAT file system)
8. Restore all data, to the micro SD.
2. Select micro SD - Continue
3. Click S.M.A.R.T - click Get Smart Attributes
4. Click LOW LEVEL FORMAT - click Format this device
5. Wait until the process is complete - press OK
I hope this information helps. Thank you for using FixYa!
1helpful
My micro sd card is locked how to unlock
Hi, i have here a photo that will show you on how to remove write protect on a micro SD.
1. You need to insert your micro SD into an adapter. 2. Unlock the micro SD through your adapter as shown below. 3. Once done, your micro SD is no longer write protected. eibraz_16.jpg
NOTE: The lock switch doesn't lock the micro SD into the adapter; The lock switch doesn't lock the data on the micro SD; The lock switch simply tells the "user" not to write. It just says "please, don't write me."
3helpful
When i try to format my micro sd card system shows remove write protect how can i format it
I hope this helps.
2helpful
2gb micro cruzer causing the pc to restart
Do you have another USB device which you can use to check if it will come up with the same problem? There are 3 things which could cause it to freeze and restart. It could be a problem with the software device driver needed to detect the USB micro cruzer, the USB port itself or it's the USB micro cruzer. One good thing worth to try is plugging your USB micro cruzer on another computer to check if the problem will also occur there. If it does, then it's isolated to the USB device. If there's no other computer available, 1) Try to run an anti-virus and anti-spyware scan on your computer, 2) start up your computer on safe mode and try to check if it'll occur there as well. 3) If it doesn't occur under safe mode and your able to access your USB device, try to run an anti-virus and anti-spyware scan on your USB device to check for problems there. 4) If all else fails, then it could be a problem with the USB device. hope this helps.
Computer mouse
Is it PS/2 or USB? If it's PS/2, the port will be round and you need to restart the computer to use it. If it's USB you should have seen windows installing the drivers for it. If you didn't, try a different port.
Top SanDisk Computers & Internet Experts
k24674
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
