The dishwasher counts down to 1, then just keeps running. When I open the door, water is still going and suds fill the bottom of the dishwasher. When I close it again and press the start button, it goes to 13, then counts down to 1 and keeps running again. The other day it was reading 58 minutes left in the cycle. When I looked a few minutes later, it was 74 minutes. A time or two before, it stuck on 1 but then operated correctly for a few days until today.
I have the same problem with my Bosch SHU5312. It counts down to one but never finishes and I have to reset it to drain it. Where is the control board and how do I get it out? Are there any diagnostics I can run to help confirm the problem?
It has been a occasional problem.. have to keep shutting door a number of times until it allows dishwasher to start. Like sensor going bad or something.
I emptied the water from the dishwasher with a sponge and removed the filter, cleaned it removed the water from the hole where the filter is and wiped the interior dry. When i close the door to start it the pump seems to working but sounds like it is sucking air. I have then opened the door and put about 500ml cold water in dishwasher and closed door again. this seems to make it sound more normal and i can see water has been coming out of the rotating arm jets. But it still only goes to 1 minute and then runs on. The small dome by the side of the lower arm seems to activate a pump when lifted slightly so i presume this is normal. can you suggest what else i could try to try to get the machine to reset to cycle properly. Also when i turn on to 50 degrees wash cycle the time indicated is only 55 minutes instead of usual 130 approximately.
stays in pump out count in window says 1.3 goes to pump out may get to 1 never stops getting hot smell if leave it running.
