SOURCE: Running water in Geberit Starck Toilet
I hate to say it but you may need a pro on this one, if you want I can try to walk you threw it but let me know. [email protected]
SOURCE: my toilet takes like 15 min to fill? have a
hi,
Sounds like the fill valve is the problem, you can change them literally in 10 minutes.
thank you for using fixya,rate my answer
vijay
SOURCE: my toilet cistern is continually hissing
Hi I have exactly the same problem, in fact it could have been me writing this - 3 toliets fine, main bathroom hisses. The Geberit flushing ciphen on the left (the smaller one) has been replaced and there is still a problem. If you look carefully,the water level needs to come up over the lip of an opening on the Geberit part and this causes the valve mechanism to shut off and stop the hissing. It is fine for about 40 minutes and then the hissing starts again if you don't flush it. The reason is that the water level has gone down but there is no obvious signs of where the water is going. It could be that the central flush mechanism is leaking slightly. I am going to replace this part next. If I were you I'd see if you are getting any water leakage into the pan when toilet not in use to see if the water level in the cistern is going down James T
SOURCE: my geberit in-wall toilet won't
Shut off main water supply
shut off water value going to your wall mounted toilet.
look under your apartment or the room ajoining the wall unit.
look for hidden wall space above unit
Easy! I had the samw problem with my cistren which is Geberit. There is a diaphram in the WC filler valve unit which may need replacing. My plumber gave me one FREE! I replaced the old damaged one and hey presto it's fixed. There is a web site that sell these diaphrams follow this link if it helps: www.toiletspares.co.uk
Cheers! Xmas round the corner!!!!!!!!!!
