The display or viewfinder operate fine in playback mode but when swithched to camera mode they remain a grey colour (as if the lens cap is still on, which it isn't!) The CCD does not seem to be picking up an image.
Sounds like you may have a problem in the auto iris curcuit or the auto settings was switched to manual and the lens is closed. Check first to see that the lens is setup in auto mode. If it is then the auto iris as i said before is bad or stuck closed unless the small caps in that curcuit went bad as they always do after a few years. Good Luck
Many thanks techman - I switched it on to try your suggestions and it seems to have started working again on its own!! Maybe it was stuck closed as you suggested, if the problem re-occurs I will give your suggestions a try.
