Don't know how to set alarm(s) on a sunbeam digital LED alarm clock model #C38. Can you help??
It's very easy to do. First, make sure the 2 little slider switches on the far right hand side that turn the alarms on and off, are in the "down" off position.
On that clock, just to the right of the large snooze button there are 5 small square buttons. Time, Fast, Slow, Alarm set 1, Alarm set 2.
Depending on which alarm you want to set, hold down that button and simultaneously push either the "fast" or "slow" button to the left of it. The numbers will move forward fast or slow depending on which button you're pressing. Keep an eye on the upper left corner to determine when you've gone past 12 noon - as the indicator for PM will light up.
Keep holding down the 2 buttons until you get to the time you want. Then immediately release the fast/slow button. Your time is set. Do the same for alarm 2 if needed. When finished, flip up the switch for the alarm you want to activate, and you're good to go. Piece of cake! It took me a few minutes to figure it out; but after doing it one time...it's easy. Hope that helps.
I love this old Sunbeam clock. Only problem is the alarm is not very loud and there's no way to raise the volume - short of connecting wires to the speaker and using a powered speaker. Cheers!
