Nikon COOLPIX L5 Digital Camera Logo
Posted on Sep 01, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Camera says out of memory won't let me take pictures. i cleared all the pictures out and still cant take pictures. What do you think the problem is?
Kile Hines
Level 2:
Scholar:
New Friend:
  • Expert 44 Answers
  • Posted on Sep 01, 2011
Kile Hines
Expert
Level 2:
Scholar:
New Friend:
Answers
44
Questions
0
Helped
10257
Points
131
I'm assuming you are trying to use an SD card in your camera and not the internal memory. I suggest you format the memory card if you are sure there is nothing on the card. Formatting the memory card deletes everything on the card and sets it up with a file system that your camera recognizes. Follow these steps to format your memory card using your camera. 1. Turn camera off 2. Insert memory card 3. Turn camera on 4. When the memory card is inserted in the camera, the [Format card] option appears in the setup menu 5. Choose Format to format the entire card. Don't choose Quick Format 6. Wait until your card is formatted
After formatting your memory card, try turning your camera off and on and you should now be able to take pictures to your memory card.
P.S. If you remove your memory card you can choose Format Memory from the setup menu to format the camera's built-in internal memory
Anonymous
Level 1:
New Friend:
  • Contributor 31 Answers
Anonymous
Contributor
Level 1:
New Friend:
Answers
31
Questions
0
Helped
6838
Points
98
Try formatting the card, instead of the "Delete All" option. Maybe there's some corrupt data on it and formatting will clear that. Other than that, does your memory card have a lock switch? Get it out of the camera and check. If it's there make sure it's in the upper position (meaning that the card is unlocked - writable).
1 Related Answer
Anonymous
  • 96 Answers
  • Posted on Jun 23, 2011
SOURCE: When i turn on my camera, it won't read my
If the card was one that was previously used in another camera, you can't use it in this camera without formatting it. Move the pictures to a computer and format the card via the camera (remember that all data on the card will be erased). Before formatting the card however, make sure the battery has sufficient charge as this process can take some time. Also remember to never interrupt this process as it can damage the card. The format option can be found in the settings.
Note: pictures taken on one camera can't be viewed on another camera.
Testimonial: "thanks !!!!"
Samsung PL50 with Samsung 2GB memory card says 'memory full' even though I've cleared down the memory via my laptop.
Have you actually formatted the card in the camera ? Just copying the photos does not remove them from the card
5helpful
What's your problem? cant import photographs from my camera to my pc
You neglected to specify the make and model of your camera, so I'm going to assume it uses a memory card of some type.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Oct 26, 2012 • Cameras
Cant transfer pictures from from camera to pc
1helpful
I cant download from the camrea
You neglected to specify the make and model of your camera, so I'm assuming it uses a memory card of some type.
May 09, 2012 • Cameras
Camera powers on and everything seems to be in working order except it will not take a picture. could it be full?
That is one possibility. Try using a different memory card, or clear out the one you're using.
My camera won't show any pictures from my SD card
You have to change the 'storage' to 'memory card' or 'external card' from 'internal memory' or 'camera' using the camera menu.
Cant find how to download my memory chip{pictures] into the computer. Did it once, but cant find how i did it, only thing that shows up is for a disc.
1helpful
How do I clear the memory in my M447 camera and/or upload the pictures on my computer
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
After downloading your pictures, put the memory card back into the camera and format it. This will clear the card and prepare it for further use. FixYa is full of people asking how to retrieve pictures from cards that haven't been formatted recently.
1helpful
When transfering pictures from camera to PC EasyShare will not transfer some pictures. "picture already exists" in My Collection. These are all new pictures taken with blank memory card. This occurs even...
Scrap the camera! Kodak hasn't and won't address the problem. Most picture download software won't recognize the camera. The only solution is to remove the memory card from the camera, put it in USB adapter and treat it like a flash drive. Cumbersome. Awkward. Stupid. After you scrap the ****, tell your friends so they don't make the mistake of buying a Kodak.
I cant download pictures to the computer nothing happens when i plug it tn.
Try NOT connecting your camera to your computer.
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
