Posted on Sep 01, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Dell/Zylux A425 2.1 audio system for a Dell PC. The speakers don't seem to turn on at all - no sound, no pops on power up and no indicator light on control speaker. Circuitry shows power at output of bridge rectifier inside the woofer (about 26VDC). Is there a schematic available or a part that is most likely bad? Quad amp? other regulator circuitry?
petrillaa
Level 1:
New Friend:
  • Contributor 8 Answers
  • Posted on Feb 07, 2013
petrillaa
Contributor
Level 1:
New Friend:
Answers
8
Questions
0
Helped
4302
Points
21
It seem your amplifier doesn't work, nothing to do with your computer, you can check with any other source lik eMP3 player, etc. If you take apart the box, there are some SJ4558 dual opamp. In my panel three of them were not working. Check if they are working or not. TDA 8947J is the power amp ic, download the datasheet.
You can also check the input PINs there are article about it.
After I replaced the 3 bad opamp, worked fine like new.
I have a Dell/Zylux A425 2.1 audio system for a - 2_16_2014_9_11_31_am.jpg
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 27, 2012
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2094
Points
0
Necesito los controladores para el subwoofer a425 esque compre la bocinas pero no me las lee porfabor un link o si tiene los controladores fabor de enviarmelos al correo [email protected]
Brian Sullivan
Level 3:
An expert that gotĀ 20 achievements.
An expert that gotĀ 10 achievements.
  • Dell Master 27,725 Answers
  • Posted on Sep 01, 2011
Brian Sullivan
Dell Master
Level 3:
Answers
27725
Questions
Helped
5663215
Points
79191
If your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
if you dont have a motherboard disc you will have to download the drivers
if you need help downloading sound drivers post a reply
hope this helps you
I need the millivolt output recommendation
You are talking about a Meter to measure the Voltage and Amperages. If you do not have one; and need to measure the power, current, or resistance values; take the speaker to Radio shack and they will do it for you.
I have the sub woffer only would like to use on my comp
No problem....just plug the subwoofer into your Green Port on the computer sound section. The Right and Left channel will merge into a monaural sound and come out of the speaker as if you were listening to music from a radio.
8helpful
Wireing diagram for Dell A525 Zylux Multimedia Computer Pc Speaker System W/subwoofer 2.1
pin 1-G
pin 2-R in
pin 3-L in
pin 4-PG
pin 5-R out
pin 6-ST BY
pin 7-VC
pin 8-L out
pin 9-PG
Popping sound
Check for any external shorting of the speaker wires. Check for kinks or cuts in the cable that feeds the speakers. Also check the posts or socket at the back of the speakers for damage or wiring shorting out. Proactive IT Support PC Repairs Laptop Repairs Custom Built PC Leading IT...
Speaker wires are pluged in on my dell inspiron 530 but not working help
    • 1 Make sure that your computer and speakers are plugged in, have power and are turned on. If the speakers are plugged in but don't appear to have any power, plug them into a different outlet. Some speakers are self powered and use a USB cable to supply power. Make sure that the USB cable of your speakers is connected securely to the USB port of your computer.
    • 2 Retest the sound. If you still don't have any sound, make sure the cable connecting the speakers to the computer (known as a 1/8-inch TRS cable) is plugged into the green audio output jack on the PC.
    • 3 If you're using self-powered USB speakers, remove the USB cable and plug it into a different USB port. If you're using outlet-powered speakers and have a working set handy, replace the suspected non-working speakers with the working pair to test.
    • 4 Navigate to the Microsoft Fix It troubleshooter (windows.Microsoft.com/en-US/windows/help/no-sound-in-windows) to automatically detect and fix sound playback or hardware problems. If that doesn't work, proceed with the next step.
    • 5 If you have an add-on sound card and none of the hardware or software fixes helps, you may have to replace the sound card. If you use on-board sound, it will probably pay to purchase an inexpensive sound card rather than a new motherboard. Check the system BIOS to determine whether you have inadvertently disabled your on-board sound.
    • 6 Navigate to the "Start" menu and select the "Control Panel" and "Sounds and Audio Devices." Then click the "Volume" tab. If everything is grayed out, proceed to Step 7. If the "Mute" box is checked, uncheck it. In "Device Volume," make sure that your volume level is set to a comfortable volume level for your speakers.
    • 7 Click the "Sounds" tab. Under "Sound Scheme," determine whether "No Sounds" is selected. If it is, click "Sound Schemes." A drop-down list will appear. Select "Windows Default" as the scheme. To test your sound now, click on a sound listed below the "Program Events" window. The sounds will be indicated by a small "Speaker" icon located next to them. Left-click the sound once, then click the "Play" button. If you still don't hear sound, proceed with the next step.
    • 8 Click the "Audio" tab. Under the "Sound Playback" option, make sure your sound card is selected as the default playback device. Usually, only one device appears here, unless you have multiple playback devices installed.
    • 9 If everything is grayed out, you either do not have a playback device installed or your drivers are corrupted and need to be replaced. Drivers help hardware and software function together. Fix this by reinstalling the appropriate drivers. Do this by navigating to the "Start" menu and right-clicking "Computer." Then select "Properties" from the drop-down menu. Click the "Hardware" tab and then click the "Device Manager" button. The Device Manager will open.
    • 10 Look for either a red X or a yellow question mark listed under "Sound, Video, and Game Controllers." If a red X appears, right-click the device with the X and select "Enable" from the pop-up menu. Test your sound at this point. If a yellow question mark appears, right-click the device, click "Properties" from the pop-up menu, and then click the "Driver" tab on the window that appears. Next, click the "Roll Back Driver" button to roll back to the previous drivers that were functioning correctly. Restart your computer when prompted.
    • 11 As a last resort, you can uninstall and reinstall the device. To do this, right-click the device and select "Uninstall" from the pop-up menu. Restart your computer. Windows will automatically detect and install your audio device upon boot-up. If you still don't hear any sound from your computer speakers, contact a qualified computer technician.
3helpful
2answers
Where can I download a driver for Altec Lansing ADA745 speakers?
HI, maybe theres been a bit of confusion but your Altec Lansing ADA745 speakers shouldn't need any drivers.
Its kind of similar to you plugging in a pair of headphones into your cumputer, they should work just fine.
Are you not getting any sound? Post the details of your PC (is it a dell?)
model number etc... and describe your problem
You probably need audio drivers for your audio device(inside your pc on your motherboard),
Top Dell Audio Players & Recorders Experts
SmartAviator
SmartAviator
ADMIN Andrew
ADMIN Andrew
 Grubhead
Grubhead
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
