1. Check the seal all the way around the freezer do this by taking a piece of computer paper and trying to slide it in to the seal. It should not go in to the seal. If this is tight your problem is not with the seal.
2. Ensure that you are shutting the freezer door properly everytime. 90% of service calls of food having frost on them in the freezer is due to the customer not fully shutting the door.
3. If you are 100% sure 1 and 2 a good take a white sealent and run a bead of it around the casing of the freezer where the plastic meets with the out side caseing.
A door gasket is the most likely cause with it letting in moist air from the house. The gasket should be snug on a dollar bill all the way around the door.
Hi Dale Dibb, thank you for your inquiry!
I understand that the food inside of your Frigidaire freezer is getting frost on the inside of the packages. I would recommend turning the temperature up inside of your freezer. Additionally moisture inside of the package would cause frost to develop on the inside of the food packages.
Please assure that all possible moisture has been removed out of the food packages prior to placing the items inside of the freezer. If there is anything else that I can help you with, please feel free to reconnect! -Matt
