Frigidaire FEQ1442ES Electric Dryer Logo
Posted on Sep 10, 2008
3 beeps and lights flash when I push the start button
When I push the start button the indicator lights all light up, flash and it beeps 3 times. The dryer will not start. We cleaned out the lint but it still will not work. HELP
  • 2 more comments
  • towboy007 Oct 08, 2008
    I have the same problem
  • mmae66 Mar 22, 2009
    Dryer will start, but sounds three beeps continuously.
  • Happycamper7 May 11, 2010
    Hey CJ, Did you ever find a fix for this problem?
  • Anonymous Mar 12, 2014
    After replacing heating coil assembly can not get to start. All I get is flashing control light and 3 beeps.
Anonymous
Level 1:
Problem Solver:
  • Contributor 4 Answers
  • Posted on Mar 20, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
Questions
Helped
11006
Points
8
The door is not compltely closing. Make sure to push it in hard around the clasp areas. If yours has a light, the light should turn off and on as you open and close the door.
WHEN POWER ON CHAIR SPEED LIGHT BLINK .BOTH BATTERY WAS REPLACE AND JOYSTICK.SAME PROBLEM
The battery meter lights will flash a flash code when something is wrong. If the lights are flashing the same number of lights each time. get that number it is a flash code. if the lights are cascading up and down that indicates that the Joystick is locked. unlock by turning on the joystick and pushing the horn button twice within 10 sec. of turning on. Or push on button and hold the joystick gimbal forward until it beeps then back until it beeps. This should have it unlocked, if not Pride Jazzy Tech 800-800-8586
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Code in digital display does not have a E in front of it
Please let me know if you can get a number after this - if so what number shows up?
Model differences:
• Better models have a digital readout display
• Good models do not have a digital readout display
In the Better Models line, the failure codes will appear in the display as an E followed by two numbers, a number and a letter
or two letters. The control will beep and the Door Lock, Wash, Rinse, Final Spin and Control indicator lights will flash.
Example: E14. To stop the flashing and beeping, the customer may touch the Pause Cancel button. The error code remains
stored in the control but once the problem is corrected, it does not effect the operation of the washer. If the failure is something
that the customer can correct (such as the water faucets being turned off), the washer will operate normally the next time it is
started.
In the Good Models line, the control signals the failure code by flashing the five indicator lights of Door Lock, Wash, Rinse,
Final Spin and Control for the first number or letter after the E and the Start indicator light for the second number or letter
after the E. When a failure occurs, the washer stops or pauses and the control beeps and flashes the five indicator lights to tell
the customer that a failure has occurred. To stop the flashing and beeping, the customer may touch the Pause Cancel button.
The error code remains stored in the control but once the problem is corrected, it does not effect the operation of the washer.
If the failure is something that the customer can correct (such as the water faucets being turned off), the washer will operate
normally the next time it is started.
To recall an error code,
• Wake the machine by pressing any button
• Wait 5 seconds
• Press and hold the Start and Pause Cancel buttons simultaneously
• All LEDs will go blank and after a few seconds the control will signal the stored code using audible beeps and blinking
LEDs. The control will repeatedly signal the code, as long as the Start and Pause Cancel buttons are pressed.
A two-second pause between repeats affords you the ability to make accurate counts to identify the correct error codes.
Please Note the following...... on a small number of washers with serial number prefix XC4,
if the previous procedure does not perform as specified, follow the option below:
• Follow all previous steps but instead of pressing Start and Pause Cancel buttons,
press and hold Options and Pause Cancel buttons.
If the washer is a Better Model, the error code will appear in the display. Troubleshoot problem by using charts on the
following pages.
If the washer is a Good Model, the five indicator lights of Door Lock, Wash, Rinse, Final Spin and Control will flash the
number of times for the first digit of the code and the Start indicator light will flash the number of times for the second digit.
Take
separate counts of each indicator light, then repeat to confirm in order to be accurate in identifying the proper error code.
The code is obtained by counting the number of times the lights flash. Example E24: The five indicator lights would flash twice
indicating the 2 and the START indicator light will flash four times indicating the 4. The five indicator lights and the START
indicator light start flashing at the same time.
The control will pause for 2 seconds, then repeat the code as long as the two buttons are pressed and held.
Note: A letter appearing in the code stands for a number higher than nine:
A = 10 B = 11 C = 12 D = 13 E = 14 F = 15
Example Code F1: the first digit would be 15 and the second digit would be 1. If this code would appear on a washer in the
Good model line, the five indicator lights would blink fifteen times and the START indicator light would blink once.
I turn on my ps3 and the green light comes on for a short time and the it beeps three times shuts off and the green light turns red and starts to flash. If I push the power button again the red Light
you need to change your power box there is a bad connection with the wires. its over heating you might whant to buy another at game stop or take it in to get fixed. the more you messed with it it might mess up your whole system.
1helpful
How do i reset the service light on a bhm (voyager) v4 ceiling hoist?
To turn off the service light that is flashing red on your V4 BHM ceiling lift, you have to proceed this way:
1- Power off the lift with the red cord
2- On the hand controller, push on the PROG + RETURN button at the same time and maintaint it
3- Power on the lift
4- Keep pushing on both buttons, and push in order: UP, DOWN, LEFT, RIGHT.
5-The green light will flash and the buzzer will beep 5 times
6- Release all buttons on the hand controller.
7-Push on the UP button many times, till your hear 4 beeps
8-Push the PROG button once.
9-Push on the LEFT button many times, till your hear 3 beeps
10- Push the PROG button once.
11-Power off the lift with the red cord, then back on.
The service light should be off.
3helpful
KX-T3250B; the 5 red indicators on the upper right corner are flashing...
these 5 leds lights when phone is out of program. every phone should have his own indicator showing (when handset is off) his position in chain of phones. to make them stop flashing do following:
1. push and hold "PROGRAME" button until "MUTE" indicator lights (you'll hear beep sound).
2. push one "1" to "5" button on numeric keyboard depending on telephone's position in chain (must be unique).
3. push "MEMORY" button.
Now when you pickup handset only one indicator should light.
sorry, my English is not perfect :-(
3helpful
2answers
I need to reset the oil change light.how do I do This?
1. Engine off, turn ignition key to RUN - do not start engine - make sure dashboard indicator lights come on
2. Put foot top of accelerator
3. Completely depress and release the accelerator TO THE FLOOR, THREE TIMES in rapid succession, within FIVE SECONDS - press release, press release, press release. Then wait a few seconds and the CHANGE OIL light should usually flash, sometimes accompanied by a few short beeps. Once it flashes it should disappear, and it should be reset.
11helpful
How to program viper 5701 remote
Unlock doors
Push and hold f button for 8-10 seconds until amber light is on solid
Push Remote start button for about 4 seconds till amber light flashes 3 times
Put key in to IGN position
Push valet (black button) one time and release
Push and hold valet button
Push either lock or unlock on viper remote
Key out of IGN
Test unit
The horn or siren may sound afterwards to indicate SUCCESS!!!!!!
1helpful
Error code DR
Pull the tech sheet out of the dryer ( behind the lower front access panal ). The lights flashing are trying to tell you a fault code.
A copy:
MODEL DIFFERENCES: • Better models have a digital readout display
READING ERROR CODES 1. Position cycle selector knob to the 3 O’clock position.
2. Press and hold the Select and Pause Cancel buttons simultaneously for six seconds.
3. Immediately after, press and hold the START and Pause Cancel buttons simultaneously for 4 seconds.
4. Rotate the cycle selector knob to the 2 O’clock position.
On better model dryers, the error code will appear in the digital display. On good models, the five indicator lights of
Drying, Cool Down, Wrinkle Rid, and Clean Lint Filter Spin will flash the number of times for the first digit of the code
and the START indicator light will flash the number of times for the second digit. Take separate counts of each indicator
light, then repeat to confirm in order to be accurate in identifying the proper error code. The code is obtained by counting
the number of times the lights flash. Example E24: The five indicator lights would flash twice indicating the 2 and the
START indicator light will flash four times indicating the 4. The five indicator lights and the START indicator light start
flashing at the same time. The control will pause for 2 seconds, then repeat the code.
Note: A letter appearing in the code stands for a number higher than nine.
Example Code E4A: the first digit would be 4 and the second digit would be 10. If this code would appear on a dryer in
the Good model line, the five indicator lights would blink four times and the START indicator light would blink ten times.
Troubleshoot problem by using chart below.
To move on to the next code, press the OPTIONS button. To clear code, press the Select button.
To exit this mode, simultaneously press and hold the Select and Pause Cancel buttons for six seconds.
jeff.
__________________
http://www.applianceaid.com/
Appliance Repair Aid
http://www.jrappliance.ca
JRAppliance
11helpful
3answers
LOC code flashing on washing machine
Pressing the options and select buttons simultaneously for 5-10 seconds worked. For me it happened this way: on the first attempt, with the indicator lights already "timed-out" and off, pressing and holding the options and select buttons simultaneously for 5-10 seconds caused the lights to come back on and flash the "LOC" code again. But holding the options and select buttons together for 5-10 seconds a second time caused the indicator lights to stop flashing, and allowed me to start the cycle.
1helpful
2answers
3 beeps mean what
If the only thing that happens is three rapid beeps when you select a feature from the console this is usually a symptom of a defective door switch.  The door switch must be closed to complete the circuit from the timer to the heating circuit and drive motor.  If the switch is bad, or the wiring is broken, the dryer will not run.
Top Frigidaire Dryers Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
