Question about RACO INC 976 "RAC0" ADD-A DEPTH RING 1/4-1"
How in the world do i install a RACO model 976 add-a-depth ring to a single gang outlet. it just comes with two screws and some clear plastic wrapping with no instructions. I am installing a tile backsplash with 1/2" backer board and i need to bring the single-gang outlet out from the wall approximately 3/4".
  • 565 Answers
If the add-a-depth is metal it is recommended to wrap the receptacle with some tape. Slide the add-a-depth over the wires that are attached to the receptacle from the rear. That's why there is a split in the add-a-depth, so you can get it over the wires that are attached to the receptacle. Usually you will have to replace the existing 6-32 x 1 1/4" screws with 2" or so. Then pass the screws through the ears on the receptacle, through the holes in the add-a-depth and into the hole on the box. This assumes that the ears will catch the tile. If the ears don't catch the tile, take a 6 or 8 inch piece of #12 wire and coil it around the shaft of a phillips screwdriver. Cut the coil to length and it is now your spacer that goes on before you insert the screw in the hole.
Posted on Sep 04, 2011
6ya staff
SOURCE:
Jiffy toggle switch
yes, cut the wire about 18" - 24" from the plug end, then install a regular wall light switch in an outdoor style weather proof single toggle switch gang box. Available all day at your local DIY Center.
I have done this with portable pumps that I take with me on the job site at times. I do something a little different by taking one extra step for safety reasons. I use a "Double" gang box instead of a Single and install a GFCI outlet next to the switch where the GFCI is wired first and the switch is wired in after the GFCI so it is protected from any possible shock. and the pump will be protected as well.
Good Luck
Apr 03, 2014 | Dynamo Pool & Spa
There is a wallplate with 2 outlets and 2 switches that control 2 separate lights. while trying to install new switches and outlets, wires came loose and now I have no idea what is what.
Open following link to see illustration:
http://waterheatertimer.org/images/Single-pole-switches-in-4-gang.jpg
Each residential electric box has 1 hot wire. This wire should be black.
Hot wire carries power from the breaker box.
Use tester and find hot wire.
Each device in box connects to the black hot wire using short jumper wires.
Outlets: Hot wire connects to brass colored screw.
Single-pole switches: Hot wire connects to either brass-colored screw.
Neutral wires are usually white, and are twisted together.
Neutral wires connect directly to silver screw on each outlet.
Wire going to lights connects to other brass screw on each switch.
Aug 19, 2011 | Leviton DECORA TWO GROUNDING SWITCHES...
How to connect three gang switch to control three lights, using two 1mm double core
What is 1mm double core?
Following image shows example 120Volt 4 gang switches with outlet.
http://waterheatertimer.org/images/Single-pole-switches-in-4-g.jpg
Each 120Volt electrical box has one Hot wire. This is true for ceiling and wall boxes.
Normally in a gang box, the Hot wire jumpers across all devices in the box.
Some switch boxes do not have Neutral wire. Neutral wires are usually white, and are twisted together and covered with wire nut and shoved to back of box.
Open following links for typical 120V and 240V circuits in US.
http://waterheatertimer.org/B220C.html
http://waterheatertimer.org/See-inside-main-breaker-box.html
Feel free to add a comment and describe wiring, and voltage.
For example if hot wire arrives from one of the lights.
Describe the wires that you have, and what each wire goes to for best possible answer.
Aug 16, 2011 | Cooper Industries Cooper Wiring 2158V 3...
Instructions for installation of amana water inlet valve 12544001
I know that seems like the incorrect part but it replaces the water valve that had 2 outlet hoses connected to it. To replace that;
Turn off house water supply to old valve and disconnect tubing
remove old valve and unplug the 2 wire connections and the 2 outlet hoses
The two outlet hoses were what was considered a Y hose..cut off semi clear plastic tubing a inch back where the 2 semi clear plastic tubes merge and become only 1
pull one of the plastic nuts off of the Y tube
slip it onto the end of the newly cut single tube
slip single tube into outlet threaded outlet of new valve and tighten that plastic nut
connect the 2 wire plugs onto new valve
remount to back of refrig
attatch house water supply to metal fitting that has/had protective rubber cap over it (oh of course remove procetive rubber cap and discard it)
turn water supply back on
it may up to 4 hrs for water to flow to icemaker so best to test by dispensing water through freezer door
Good luck,any questions or problems please reply and i'll help you,
Gene
Aug 12, 2011 | Amana 22.6 cu. ft. Side-By-Side...
How do i wire a 3 gang switch
Open following links for images of 3-gang and 4-gang single-pole switches.
With the 4 gang, just subtract one of the switches.
http://waterheatertimer.org/images/despard-500.jpg
If you have a 3-way switch, or outlet in the box, then add a comment with more exact information about what wires you are trying to connect, what color wires you have, and what you have tried so far. This will narrow down the possible answers and speed help.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on circuit or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 28, 2011 | Cooper Industries Cooper Wiring 2158V 3...
How to remove battery from norelco t 800 can not get to come apart after removing 1 screw on grip
Disassembling the Norelco T800 is quite easy -- once you know what to do!
* Remove the single small Philips screw that you can see near the power connector
* Twist (hard) the cutter depth ring past 9 and it will come loose.
* Now remove both the ring and the guide piece that it moves up and down
* Now pry off the cutter head (black piece of plastic)
* Now remove the metal clip that you find under the head -- press down on the two free ends and pry the other end of the clip loose.
* Now release two plastic tabs that we under the rotating ring.
* Now I just pried the two parts apart by inserting a small screwdriver and twisting. I'm not sure if there are any more tabs that can be released at this point.
* Now you can remove the circuit board (which is held in my a couple of plastic tabs).
Now you can replace the *single* NICD 600maH battery (AA size). The longest bit of this step was heating up the soldering iron!
Reassembly is the reverse.
Philip
Nov 08, 2010 | Norelco T 800 Beard Trimmer
Raco Retro-Ring : How to use with single receptacle
The retro-ring 4x4 (#206 Raco) is intended for 4 square boxes. For a 3x2 box you should use Raco 977 box supports: http://www.grainger.com/Grainger/items/3XK12?Pid=search
If you have already committed, you can use a Raco 8787 (flat 4x4 cover):
http://www.hubbellcatalog.com/raco/RACO_datasheet.asp?PN=8787&FAM=RacoBoxes
Feb 13, 2010 | Hubbell Electrical Products SUPPORT LOCK
How do use a Raco retro-ring [#206rac] with a single recepacle
Hmm .. I cannot seem to find a single plate that will do this .. you could use a sectional .. like these..
pacebw-999030t110.jpgpacebw-999026t110.jpgpace3-3391508t110.jpgIn some combination they usually can be worked to cover most any device . They arte available at all electrical supply stores ..
Please Vote !!
Moen single lever kitchen faucet leaking at base and through spray. Can it be fixed? I lost my installation manual. Are there any online?
base leak is from bad o ring or loose spout very easy fix you can get a washer kit at lowes all you need is a allen wrench(sometimes comes in kit) a pair of channel lock pliers
May 09, 2009 | Moen 7840 Camerist Single-Handle Kitchen...
Both sides are being used in my gang box. How do I add a third? Is it possible?
if it is a plastic box, you have to take to box out of the wall and install a tri-gang box.
if it is a metal box, then you can take anothre one take off one side panel andone side panel from the gang and screw them together.
May 04, 2009 | Hubbell Electrical Products 2 Gang PVC...
RACO INC 976 "RAC0" ADD-A DEPTH RING 1/4-1" Logo
2,226 people viewed this question
Top Raco Electrical Supplies Experts
Gene Haynes
john h
Are you a Raco Electrical Supply Expert? Answer questions, earn points and help others
