There are 2 different enigines on these depending upong your actual unit model number.
One had a Subaru 175 cc engine and the other was a Honda engine. For carb specifics I need the ENGINE model number. Either way... here is what you need to do:
1. Fuel selector off.
2. Remove main fuel line from the carb.
3. Use a spray can lid and check FLOW. It should fill the lid in under 8 seconds. (Feul selector OFF now) If you do not have good fuel flow here you need to inspect the tank exit port, in line fuel filter if used and the sediment bulb under the fuel selector for debris
(GOOD FUEL FLOW NOW)
4. Remove the float bowl by unscrewing the bowl nut from the bottom of the carb. NOTE positon of gaskets as you remove float bowl. Use carb cleaner and direct a spray hopefully with mini extension tube of the carb nozzle into the center of the threaded area of the bowl nut. (This cleans main fuel jet orifice / pin hole) Then spray carb cleaner using mini nozzle extension up the flat side of the float needle until carb cleaner exits the main fuel line connection. Last spray from the main fuel line connection to the float needle (reversed spray)
This usually removes any debris from the float bowl. main fuel jet and main fuel manifold Reinstall the main fuel line.
- Turn on the fuel selector and use the spray paint can lid under the float to catch fuel. It should fill in 8 to 10 seconds to the point your worried about over-flow.
- GENTLY lift the float needle to the level position. FUEL MUST STOP.
- Lower Float to resting position. FUEL MUST FLOW so that it would fill the spray paint can lid in 8 to 10 seconds. (FUEL SLECTOR OFF)
Clean the bowl nut and reinstall the float bowl. Turn on the fuel.. wait 30 seconds for the float bowl to fill completely and start unit. If it runs GREAT... If it only runs with the choke on you still have a fuel supply problem...i.e most likely the main fuel just in the threaded area of the bowl nut is still clogged. .
This should get you going. Thanks for choosing FixYa,
Kelly
