E-Machines eMachines Desktop PC Logo
Posted on Aug 31, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I cannot escape other user screen. I have no username or password for it
Azrael SRL
Level 3:
  • E-Machines Master 11,800 Answers
  • Posted on Sep 01, 2011
Azrael SRL
E-Machines Master
Level 3:
Answers
11800
Questions
0
Helped
2566898
Points
35672
Boot in Safe Mode, login as the default administrator in there and delete all the user accounts except yours and the guest one - do this from Control Panel - Users.
Can't get logged in on windows 8
Follow the steps:
Requirements:
1 ) Windows Vista or 7 DVD
1. Insert the Windows Vista DVD into the DVD drive and then restart the computer.
2. Change Boot Options 1st Priority to Optical Drive.
3. When system booting up, if the message "Press any key to boot from cd" appears, immediately press Enter.
4. On Language Settings, Time and Currency and Keyboard Layout screen, just choose the correct settings then click Next.
5. On Install Now screen, click Repair. Note: Click No just in case you get the message: Windows found problems with your computer's startup options.
6. On the System Recovery Options screen, under Operating System, click Windows Vista then click Next. Then select Command Prompt.
7. At the command prompt windows, type the following command then press Enter after typing each command:
c:
cd windows\system32
echo ~takeown /f %1 /r /d y > TakeControlOf.cmd
echo ~icacls %1 /grant administrators:F /t
ren Magnify.exe Magnify.old
ren cmd.exe Magnify.exe
8. Restart the computer.
9. On the Welcome Screen, click the Ease button.
10. Check Make items on the screen larger then click OK.
11. At the prompt, type the command then press Enter.
net user Administrator /active:yes
exit
12. Restart the computer.
13.
At the welcome screen, logon using the local administrator account.
14. Access Control Panel then click User Accounts. Select the username of the account you can't login to then remove the password.
15. Log off on the current local administrator account your are logon to.
16. Check if you can logon to your user account now.
17. Open c:\windows\system32.
18. Right click on Magnify.exe, select Properties -> Security -> Advanced -> Owner -> Edit -> Administrators then click OK.
19. Select Edit -> Administrators -> Full Control then click Apply then OK.
20. Rename Magnify.old to Magnify.exe
21. Open command prompt then type the command then press Enter.
net user Administrator /active: no
To create a new user :
Net user username/add
Windows XP/2003, Vista and Windows 7.
To add a new user account to the local computer from command line:
net user username password /ADD
Example: To add a new user account with the loginid John and with password fadf24as
net user John fadf24as /ADD
To add a new user account to the domain:
>net user username password /ADD /DOMAIN
Note that we do not need to specify the domain name here.
Example:
net user John fadf24as /ADD /DOMAIN
Rename a user account from windows command line
We can use below wmic command to rename a user account from command line.
wmic useraccount where "name='username' " rename new_username
Ex: To rename the user account techblogger as win7techblogger
wmic useraccount where "name='techblogger' " rename win7techblogger
Net use command does not have any switches to rename a user account.
Few more Advanced uses of net user command.
To specify user full name while creating the user account
net user username userpasswd /ADD /FULLNAME:"User_Fullname"
To specify that the user is allowed to change the password
net user username userpasswd /ADD /PASSWORDCHG:Yes
To restrict user not to change the password:
net user username userpasswd /ADD /PASSWORDCHG:NO
To specify when the account expires we can use /EXPIRES switch.
To specify if the user must have a password set we can use /PASSWORDREQ switch.
How to create a new administrator account from command line?
An administrator account can't be created directly from command line. We first need to create a user account and then add the user to the administrators group.
Errors:
If you don't have privileges to add new user account to the system, you would get an error like below.C:\>net user John /add
System error 5 has occurred.
Access is denied.
C: \>
if cant able underatand send me your mail id..
I son has changed my username and password, i still have the password to get into the bios screen but has no option to boot in administrator or change the user/passwrd. HP MINI 110 1081TU
Restart the system let come usersname screen,press CTRL+ALT+DELETE key press on the keyboard same time.on the username u can type administrator and login,then right click on my computer-click on manage-computer management screen appears then leftsidepane you can see Local users&Groups,click there,on right side pane doubleclick on users,u can see there ur usersname,which userpassword u forgot rigtclick on the same user click on set password then proceed and reset or u can put there as new password.then log off and select the user.
I forgot my password for my imac, and i dont have the disk?
Reset 10.5 Leopard & 10.6 Snow Leopard password
  1. Power on or restart your Mac.
  2. At the chime (or grey screen if your chime is turned off), hold down Command+S on your keyboard to enter single-user mode.
  3. Type mount -uw / and press Enter.
  4. Type launchctl load /System/Library/LaunchDaemons/com.apple.DirectoryServices.plist and press Enter.
  5. Type ls /Users and press Enter. This lists all of the usernames on the computer - helpful if you don't know or remember what these are.
  6. Type dscl . -passwd /Users/username password and replace "username" with one of the users displayed in the previous step. Replace "password" with a new password of your choice. Press Enter.
  7. Type reboot and press Enter.
Reset 10.4 Tiger password
  3. Type sh /etc/rc and press Enter/Return.
  4. Type passwd username and replace "username" with the short name of the user account for which you'd like to reset the password.
  5. Type your desired password and press Enter. It won't show itself on the screen, so be careful what you type. You will most likely have to enter it again to confirm.
  6. Type reboot and press Enter.
5helpful
How do I change the password on the Actiontec wireless router? (Not the WPA key, but the web interface password. I just want to change it from the default "password1")
  1. Open a Web browser. In the “Address” text box, type http://192.168.0., then press Enter on the keyboard.
  2. The Web Configurator’s “Main Menu” screen appears. Select Setup/Configuration.
  3. From the Setup/Configuration screen, select Admin Username/Password from the menu on the left side.
  4. The “Change Admin Username/Password” screen appears. Enter a new user name (optional) in the “New Username” text box, then a password in the “New Password” text box. Re-enter the password in the “Re-enter New Password” text box. Make sure to write the user name and password down and keep them in a secure location.
  5. Click Save and Restart at the bottom of the screen.
  6. The “Save and Restart” page appears. Click the Save and Restart button to save the settings changed in the Change Admin Username/Password screen.
  7. Once the Gateway has rebooted, the password is active.
You can also download a user manual from here, or - if you have any more questions - just come back here and leave a comment - I'm happy to help.
5helpful
2answers
How do i unlock my computer if i forgot my username and password
As far as I know , there are two main methods to solve the windows password problem as follows:
1st Method:
Start system and when you see Windows Welcome screen / Login screen, press ctrl+alt+del keys twice and it'll show Classic Login box. Now type \Administrator\ (without quotes) in Username and leave Password field blank. Now press Enter and you should be able to log in Windows.
Now you can reset your account password from \Control Panel - User Accounts\.
Same thing can be done using Safe Mode. In Safe Mode Windows will show this in-built Administrator account in Login screen.
2th Method:
Windows password reset software:
for example:Windows Password Reset. It is easy and convenient to use.
http://www.resetwindowspassword.com
I can not remember my password so i can use my wi fi. So how do i reset my password. i can log on to the router can i change it in the settings?
Reset
Pressing the Reset button for 5 seconds restores the router to its original factory default settings.
Log in to the Router
This section will explain how to log in to your router using the following steps:
1. Launch your web browser.
2. Enter the URL http://192.168.1.1 in the address bar and press Enter.
A login screen like the one below will be displayed after you connect to the user interface.
Note: There are three account types, each requiring a different username and password.
• The user account provides limited access to certain configurations (username / password: user / user).
• The admin account can perform all functions
(username / password: admin / admin).
• The support account is for ISP technicians for maintenance purposes
(username / password: support / support).
Note: Passwords can be changed at any time.
3. Enter your user name and password, and then click OK to display the user interface.
Note: This manual has been prepared using the admin user name
2answers
Forgot my password
RESET PASSWORD FOR ANY USERNAME
  1. Reboot the computer
  2. Right after the bios is finished, hit F8 (or F2,10,12)
  3. Select ‘Safe mode’ or ‘Safe mode with networking support’
  4. Windows will boot up to the logon screen. Click administrator, 9/10 there is no password.
  5. Do, Start->Run->type ‘command’
  6. At the prompt, type ‘net user’ which will display a list of usernames. Find the one you are looking for, try ‘net user username’ for them all. Type ‘net user /HELP’ for more info.
  7. To reset the password type ‘net user username *’ where username is the username you want to reset.
  8. For no password, leave blank.
  9. Now, reboot and you can login as that user.
1helpful
Unable to set up internet connection - option greyed out
in order to connect to internet you require a username and password
that user name and password will be given to you durin first time installation if you dont remember the username and password call up your broad band help desk. they will help with the user name and password.
if you are aware of the user name and password ,
you need the configure the internet setup using the user name and password
i ll give the steps to configure the user name and password in windows XP operating system
1 click on "start" button at bottom left of your desktop
2 click on control panel
3 on left hand side of the window click "classical view"
4 then click on the icon network connections
5 there you will find "create new connection"  or "new connection wizard"on the left hand side just   double click on it
6 a new dialog ll appear click next
7 on the next screen select "connect to internet" and click on next
8 on the next screen click on "setup my connection manually" then click on next
9 on the next screen select the option "connect using a user name and password" and click next
10 you will be asked for ISP name "for eg:fill in AT&T"
11 on the next screen you willlbe asked for user name and password , fill in the respective details
for eg: sam @att.net :username
            ******** :password
12 den click finish
you will find an icon in the desk top by now. just double click on that icon and try browsinn
you must be up and runnin ! ! !
2helpful
Can't remember my password
u can login but at login screen press ctrl+alt+del twice then screen will appear in black colour with username and password then type username as administrator and press enter it will login then after logging in go to control panel,user accounts double click on user and change the password of user or delete that particular user account and create a new one and restart the machine .
I have just got a new laptop and i put a password in to start it up and i dont no my password now and cant start my computer up now how can i get passed that
Top E-Machines Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
