There are two sets of adjustments. Down position and down force, If the travel is set to far in the down position the max down force setting will trip and the door goes back up.
Adjust he down position until a slight gap is visible in the down position. Adjust slight steps until no gap is visible.
If return trips increase the down force slightly . Position adjustments are on the side, down force blue knobs on back. Note adjustment positions before beginning so if you get confused you can start over.
Hope this helps?
SOURCE: Oven Door is locked and will not open
On many freestanding stoves the lock motor is located in the right rear (looking from the front) with a long rod connected to the lock. Pull or push the rod to move the lock to the open position..
SOURCE: GARAGE DOOR OPENS BUT WILL NOT CLOSE AUTOMATICALLY
is bulb on motor flashing 10 times. then you have electric eye problem. otherwise, sounds like you need to increase down force a hair. adjustement is on logic board, right knob.
SOURCE: Garage door opened, won't close
If you can press and hold the wall button and the door will go down, you have a photo eye issue. Check the photo eyes at the bottom of the door.
SOURCE: My oven door is open but the panel is flashing "LOCKED"...
Pull the plug, wait 5 minutes and plug it back in. Don't touch anything! First check to make sure the door closes. If it does you are ready to set the self cleaning mode.
SOURCE: My garage door opener won't close the garage door.
Most likely your door sensors have been bumped and are not aligned properly. Make sure they are pointed at one another and the small light on each one is lit and not blinking.
