Hi
Dishwasher not draining issue usually occurs due
to kinked drain pipe, clogged drain filter or drain pump. First make sure that
the drain is not clogged and remove clogs if present. If no visible lint is
present then remove the lower front access panel to check the drain filter and
drain pump for any clogs, you'll need to clean the drain filter and drain pump
completely. Also, check for any food pieces stuck near the pump impeller &
clean the chopper assembly. Please note that dishwashers don't drain out the
complete water such that heating element doesn't overheat. Hope this helps...
Please post back for any further assistance.
Daniel
Two things to consider....clean water or
dirty water?
Clean water usually indicates the fill valve
is not shutting off all the way and the fill valve is "weeping" water
in all the time = new fill valve time!!
Dirty water usually is not a dishwasher
problem but more of a plumbing issue. Often the sink drain that carries the
sinks water outside is not fast enough and some of this sink water is backing
up into the drain hose and filling up the dishwasher through the drain hose.
The drain from the sink to outside needs attention as this type of a problem
indicates a slow house drain for that sink.
The dishwasher drain line should be clamped to the top underneath part of the counter before entering the sink drain plumbing, this may help the water from coming back inside the dishwasher.
