SOURCE: HI, i have a gucci
To set the time, you normally pull out the crown and rotate it. The main (large) second hand is associated with the chronograph function so is stopped at 12 when no using chronograph. There should be a little second hand in a little round area on dial that is moving.
SOURCE: How do I open my gucci watch to change batteries?
Get a #0 1.6mm precision Phillps screwdriver (these are brittle) or similarly strong, thin piece of steel.
Hold the watch upside-down across your index finger while gripping the straps tightly between your index finger and thumb on one side, and index finger and middle finger on the other (ie. squeeze the strap around your index finger).
On the underside of the watch, stick the tip of the screwdriver under a square slot where the watchband is connected at an angle perpendicular to the strap. Firmly pry upwards on the cover on one side, then the other, until the cover pops off.
The battery is a Renata 379.
To put the cover back on, align the square slots precisely with the ends of the straps (keep these out straight), then firmly push the cover straight down until it "snaps" shut.
SOURCE: How to Open a Gucci watch
Most watches are either screwed on and typically have a series of small notches around the circumference of the case back. A special tool is generally called for. Otherwise they are "snap back" . These are simply pressed on. To remove you can carefully use a regular knife in the absence of a "case knife". There is usually a small gap/groove/notch area to insert the balde and lift the back off.
SOURCE: i'm trying to find out what is the current value
mcdevito75 here, Without seeing the watch itself, very hard to tell, the age and condition and of course how well it"s working all count towards it"s value, although GUCCI is a powerfull name in watches all the mentioned factors count toward any watches value. I would figure your Ladies GUCCI watch is valued any where between the $250.00 $350.00 range. Check with a local Jeweler in your area also, for your watches value.
SOURCE: Gucci watch looses 10 mins a day after battery change
Please refer this matter to expert. Kindly run through below website for assistance in finding the nearest outlet/dealers in your country.
Gucci
