OE error code indicates that the washer is unable to drain the water it used during the wash cycle. OE can be triggered by a kinked drain hose or a clogged drain pump filter..... please clean drain hose back side of washing machine.. Thank you
The OE error or fault code indicates that the washing machine is not draining properly. Check to be sure the drain hose isn't clogged or kinked. If that checks out, check to see if the drain pump or drain pump filter are clogged. Sometimes objects that are put into the washing machine, for example combs, money, hair pins, etc. end up in the filter. Finally, if the drain line is clear and the pump seems to be clear and functioning properly, you may need to replace the drain pump assembly.
This OE error or fault code to indicate that the washing machine is not draining properly. Check to be sure the drain hose isn't clogged or kinked. If that checks out, check to see if the drain pump or drain pump filter are clogged. Sometimes objects that are put into the washing machine, for example combs, money, hair pins, etc. end up in the filter. Finally, if the drain line is clear and the pump seems to be clear and functioning properly, you may need to replace the drain pump assembly.
The manufacturer has assigned the OE error or fault code to indicate that the washing machine is not draining properly. Check to be sure the drain hose isn't clogged or kinked. If that checks out, check to see if the drain pump or drain pump filter are clogged. Sometimes objects that are put into the washing machine, for example combs, money, hair pins, etc. end up in the filter. Finally, if the drain line is clear and the pump seems to be clear and functioning properly, you may need to replace the drain pump assembly.
This error code OE means the tub is not fully drained 10 minutes after the drain pump is turned on.This is possibly due to a clogged/kinked drain hose or the drain filter is blocked. Make sure the drain hose is clear then open the filter door located at the bottom left front of the machine. Drain the remaining water from the tub through the emergency drain hose located in the filter door area. Once completely drained, turn the knob counterclockwise then pull out and clean the filter. Reach in the pump impeller area and turn it with your finger. Replace the drain pump if the filter is clear and the impeller is broken or restricted and cannot be freed.
The OE code appears because the machine is not fully drained after 10 minutes to start the spin cycle. The machine cannot spin with water still not drained due to clogged/kinked drain hose, blocked pump filter, or pump not working. Remove the drain hose from where it is installed and drain the water from the machine into a basin that is enough to hold the water. The drain hose or the pump filter is indeed clogged/blocked if the water does not drain/flow by gravity into the basin.
Check to make sure that the drain hose is clear and not kinked. Open the pump filter cover then remove and clean the filter. Reach in the pump impeller with your finger and turn it to check whether it is stuck or not.
Make sure the pump wire harness is snugly connected and intact. Replace the pump if no issue is found with the drain hose, pump filter, impeller, and the wire harness or after all issues are addressed and the fault code still appears.
You don't
have to accept or reject
and rate this post
to add information
or post comments and follow-up questions. Accepting a solution does not
stop you from communicating
with an expert. You may continue communicating with the expert as
long as you need assistance regarding the issue stated herein.
