Hi All of a sudden when evere I put in a tape the machine ejects the tape. Doesnt' matter if its rewound , As soon as a tape is in it ejected ty Diane
Besides the solutions techman listed there could be a problem with the tape as well. If you dont see anything inside the machine when you peek threw the door you might want to pop the cover off. Insect the tapes also or the tape your trying to play. If you hold the tape in both hands lable up there is a little pin on the right side of the lever if you push this pin it will rotate the door on the tape you can inspect the tape in the cassette. Sometimes machines will rewind the tape to far and it will reach the leader wich is clear and this tells the machine that it is at the begining or the end. Sometimes the tape will break. Is the machine near a window? there are light sensors inside the machine also and will sometimes kick the tape out if it gets to much light on the sensors. Try a fresh brand new tape first thing then check the inside for debris.
The reason for this could be many things. The first one that comes to mind would be a cassette loading problem,ie the cassette you insert does not load all the way for some reason like little fingers or even big fingers put something inside the tape door and when you put in a tape it dosent let the tape settle all the way so rejects it.a falloen off tape label or sticker I have found to cause this problem. If all looks good then theres a sensor or a mecanical problem that should be serviced by a quilifyed technician.
the t.v. won't stay on it only stays on for about 10 minutes and it says eject t on the screen so if you can help me here is my email address [email protected] and the brand of the t.v. is Emerson EWC 1301
tape is not loading
