Nikon D3000 Digital Camera Logo
Posted on Aug 30, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I dropped my daughters Nikon d3000 and now all pictures taken are coming out with just stripes. Does anyone know if this is the camera or the lense
Anonymous
Level 3:
Brigadier General:
  • Master 11,967 Answers
  • Posted on Aug 31, 2011
Anonymous
Master
Level 3:
Brigadier General:
Answers
11967
Questions
0
Helped
2201052
Points
38521
This is a camera problem. Are the stripes just on the screen or are they actually on the pictures when you download them to a computer or try to print them? If just on the screen, the screen may be cracked or the ribbon cable connecting the screen to the motherboard may be dislodged. Can you review previous (before the fall) pictures and can you see the menu items without stripes?...If so, then the screen is ok and the problem is deeper inside the camera.
NIKON D3000, SHOWING RAINBOW STRIPES WHEN I TAKE A PICTURE
I think you're in for a repair that could be expensive.
Check Nikon tech support at www.nikon.com and see what they advise. I don't think abuse such as dropping the camera is covered under the warranty but Nikon may be able to suggest something that might help you avoid having to send the camera in for repair.
1helpful
Nikon d3000
did you try a different lens if you did send your camera in for repair . the lens gets damaged easy
Fuzzy Pictures w/ Nikon D3000
If this is a new camera, it should still be under warranty. I suggest you contact Nikon before doing anything else to determine if the repair would be covered under warranty. Nikon also would be in a position to advise you as to what the problem might be so that in the event that the repair is not covered under warranty, you don't replace the wrong thing.
1helpful
Promaster lense fits nikon D3000 but camera says lens not attached
Promaster makes many different lenses. Some of their older lenses do not have the electronics to communicate with newer digital cameras, and you have to shoot in Manual mode. Could you tell us which lens you're asking about?
Nov 30, 2012 • Cameras
2helpful
Does anyone knows how a Vivitar 75-260mm lens will works on nikon d3000?
Vivitar makes lenses with a variety of mounts. Assuming the lens in question has a Nikon mount then it will fit perfectly well on a D3000. If the lens has a Canon mount, for example, then it will not fit at all.The lens is a manual focus lens, so autofocus will not work. You'll have to focus by yourself.The lens also lacks the electronics to communicate with the camera. You will have to shoot in the Manual exposure mode, setting the shutter speed and aperture yourself, without any help from the camera's light meter.
Can you use the Quantaray 70-300mm on the Nikon d3000 and or can you use Nikon 55-200mm on the d3000
The Nikon lens, absolutely.
Quantaray makes their lenses with a variety of mounts. A lens with a Canon mount, for example, will not fit on the D3000. Assuming the lens has a Nikon mount, then yes, it will work with the D3000.
4helpful
I have a Nikon d3000 and a Tamron AF 55-200mm lens. I cant get the lens to autofocus with my nikon
The Nikon D3000 does not have a focusing motor built-in, relying on the lens to have a motor. The Tamron AF 55-200mm does not have the necessary motor; it only auto-focuses with Nikon cameras that have the motor in the camera body.
For Nikon lenses, you need lenses designated AF-S. For Tamron, you need lenses designated USD and/or BIM.
That probably wasn't the answer you wanted to see, but there it is.
D3000 Digital Camera with 18-55mm lens: hi,i brought a nikon 3000 , is it compatible with ...
ALL Nikon AFS branded lenses are compatible with the D3000. The AF lenses are usable in manual mode. Sigma, Tokina and Tamron lenses without the built-in motor are manual mode as well.
To be sure, check the manufacturer;s websites.
Hope this helps,
Andrew
1helpful
I'm looking to buy a digatil camera a D3000 and
See my answer to your other post.
One more addition for the D3000. Older autofocus lenses without a built-in motor will not autofocus on the D3000. Only AF-S and AF-I lenses will autofocus on the D3000.
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
