Refrigerators Logo
Posted on Aug 30, 2011
Hello. I've had the above f/freezer for about 6 years and its been fine. Over the past two weeks i've been getting small amounts of water going on to the floor, from the freezer side - it's as if its defrosted.It seems as if its coming from the inside as there's some ice at the bottom. Any ideas?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 30, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
52
Points
Sounds like a plugged drain. Your FF defrosts 2-3 times a day and if the drain plugged the next defrost water just runs out the door.
Refrigerator leaks
If it a frost free fridge it should self defrost every 6 to 8 hours all by its self. If you see ice or frost buildup in side the freezer usually back wall harder to notice if the cooling fins are just under the freezer floor but above the fridge ceiling or better picture it as the fridges taint. Sounds like the fridge is having defrost problems and if it every once in awhile does go into defrost or you do it, all that water flows down a hose and out the back around the compressor. Heat from the compressor or other gadgets evaporate the water. If it only defrost a few times a year it is going to overflow the catch basin. Easy to check some times catch basin or drain hose move check back bottom or remove front cover look if bottom catch basin. Main fault is defrost timer stuck in run, location all over in or out, defrost element around cooling fins,defrost thermostat on cooling fins,wiring to / from / joining the last two.
Maytag neptune frontloading washer overflow
If you cannot clear the line, you will need to replace it. Here is the line to order.
2answers
Model ZHSC02PP-- Mini fridge no longer cooling (18-24 months old)
Has it sat any amount of time without usage? Check and see if any of the 4 walls is cool, it could be that the fan isnt working.
Hello- I have a Kenmore Elite refrigerator model# 795.77563600 which leaks a small amount of water under the front left corner only after every 1-2 uses of the water dispenser in the door. I've...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
I have a top freezer Hotpoint refrigerator at a lake home. It's about 6 years old. I've been getting water in the refrigerator compartment. I've tried to clear the hose on the back by...
Leo Ponder
imufo2
Eric, My side by side whirlpool's return air vent keeps freezing over. I've removed the back and done the Hair dryer thing and the fridge works for about a week, give or take and start all over....
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
The cold control needs replacing. Thats the knob with the numbers that turn the Ref OFF and ON.
What I do is call my local Appliance Parts Store with my model no. They are extremely helpful .
If you need more help, Go here:
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Leo Ponder
imufo2
I have a top mount Kenmore refrigerator, model no. 106.60272990, serial no. EK2929089. It is about 10 years old and works fine except for one problem that has kept recurring every 2-3 months over the last...
hey barry I had the same problem and i recently broke down and called a repair service, the repair person installed a small aluminum piece he refered to as a heat probe, on the heater coil which is behind the back plate in the freezer, he claims this will solve the problem, evidently the water created in the defrost cycle freezes before it can get down the drain, thus the drain becomes blocked with ice, subsequent cycling of the heater for defrost causes more water and ice buildup and the water overflows through air ducts into the refridgerator, I would check at an appilance parts store for this part it cost $20, unfortunatley the total cost of the service call was $ 227, My gripe is this is an obvious flaw in design and should have beeen addressed by Kenmore, if you make a part to remedy a problem then its an admission of the problem! Good Luck!
Water keeps developing on the floor below the freezer door. The seals are ok and the freezer compartment it's self is fine and doesn't appear to be leaking from there. Any advice would be appreciated....
You have a blocked drain.
There is a condensation drain at the back above the pump with a small tube that is meant to deposit water onto the pump for evaporation - the drain gets blocked so the condensation flows out through the front door. Also makes big rivers of ice at the back of your freezer behind the bottom shelf??
Solution - Dismantle the inside of the freezer - take all the plastic trim outof the back of the freezer with a screw driver - don't worry, it's only trim and goes back easily. Eventually you will see the drain collector (flat V shape) and at the point of the V is a small hole, pour warm water in this till it drains to the pump at the back, instead of down onto your floor at the front. You may need to clean the hole too as it gets gunked up.
You can also help by finding the drain tube above the pump at the back and gently inserting a chopstick or similar untill the warm water empties onto your hand !
Takes about an hour all in all and has been fixed for a year now on mine.
Sub zero 550 (14 years old) has a small but steady leak onto floor from freezer compartment. Small amount of frost buildup on inside of door. Food is frozen and the door "appears" to seal we
Right hand side wall in the freezer - take a look- any frozen water or moisture? Need check a drain line, usually defrost heater inside the freezer wall getting bad and draining water just freezing inside of it.
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
