Follow the wire back from the starter. It should bring you to the relay. Many starter relays have 3 wire going to them. Usually, 1 smaller wire, and 2 larger wires. One wire will be power from the battery. The smaller wire will have power when the key is turned to start. The third wire will carry the battery voltage to the starter during starting. good luck
SOURCE: 1997 Yamaha Waverunner not starting and no electronics
check the kill switch. If it ran recently then you must have a loose wire somewhere.
mine did the samething as sooon as i got it on the trailor i tried to start it and the starter was froze up (worked fine in the water) so i replaced the starter and tried it and nothing happend. i went into the black box and figured out my starter relay burned up trying to get power to the starter. works fine now after changing relay and starter
SOURCE: I have a yamaha triple 1100 and when I hit the button just a clic
You have a bad connection either at the battery terminals or the starter terminal. If the battery is new and fully charged and was not accidently drained overnight by another power source,then a thorough inspection of battery connections is needed. Not much else to cause this primary starting circuit problem,other than the starter itself.
SOURCE: i have a 2001 yamaha waverunner and the gauges stop working
I have a 2001 waverunner and it stoped runing in the water . Now it will turn over but won't start
SOURCE: Have a 1999 yamaha 1200 xl limited waverunner only
your starter is shot more than likey try to jump the relay in that black boxs buy jumping the two post on that round relay if it does the same its the starter if it turns over its the relay or the start **** becareful jumping the relay no fuel around air bike out and you have to take off the exhaust manifold to get to the starter
