Sony Ericsson W200i Cellular Phone Logo
Posted on Sep 10, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Walkman playback failed
I replace my memory card with 1GB, but when i paly some songs on the palylist it displays "playback failed". Whats the problem?
Anonymous
Level 2:
  • Expert 111 Answers
  • Posted on Sep 10, 2008
Anonymous
Expert
Level 2:
Answers
111
Questions
0
Helped
80476
Points
251
Good day ! you need go to the cellphone center bring your memory card to put the install of song player to the new memory card! try that , good luck ! ....
MUSIC I MOVED FROM COMPUTER TO SD CARD WILL NOT PLAY ON CELVIANO AP620 PIANO
http://support.casio.com/pdf/008/AP620_6_E_1A_web.pdf
E-48
Using a Memory Card
You can use the procedure below to play back a user
song (page E-24) stored on
a memory card without
loading the song into Digital Piano memory.
Memory Card Folders
Formatting a memory card on the Digital Piano will
automatically create the four
folders shown below. You
put playback song data into any one of the folders. You
can use the four folders to group your music data by
family member, genre, or some other categories. Use
buttons
through (folders) to select a folder.
1.Store the music data you want to play back in
one of the memory card folders.
2.Insert the memory ca
rd into the Digital
Piano's memory card slot.
3.Press the (CARD/INTERNAL) button.
4.Press one of the folder selection buttons (
through
) to select the card folder you want.
This will display the song number and song
name of the first song in the folder you
selected.
5.Use the (w,q) buttons to select the
song you want.
6.Press the (PLAY/STOP
) button.This will start playback.
•Each press of (PLAY/STOP) starts and stops
playback.
•Fast forward, fast reverse,
tempo changes, and other
operations are the same as
those during playback of a
user song in Digital Pian
o memory. For details, see
"Playing Back a Specific
Music Library Song" (page
E-24).
7.
To quit memory card data playback, press the
I am using w200 with 1GB M2.There is some unwanted noice while playing songs also sometimes playback fails.
dear sir,
this is not a big issue....what happened is,you have deleted few music files from your file manager and it is not being deleted from the playlist,actually the file is not in your mobile or memory card,but the file name is there in the playlist,so when you play music,the files which are present in the mobile is being played and the files which are not there when being played gives you the playblack failed code....
just go to the walkman menu,go to playlist and delete the files which are not in your mobile.....thank you for using fixya.
take care
1helpful
MEMORY CARD(M2) IGB 4 SE W2OOI SHOWS FAILED MSG WEN PLAYING
it may be faulty but if you format from start then replace it may solve the problem
1helpful
3answers
Sonyericsson w200i
try flashing the phone software
I have a sony ericsson w200i walkman phone, the problem i am having with the phone is whenever i am playing music on the phone, it plays for a while and then says playback failed, also when i download...
the firmware needs to be reflash on the phone to correct these issues try topsony.com or take the phone to a mobile shop and have it done.
Dec 28, 2008 • Cell Phones
3answers
Memory card problem
BECAUSE W200i DOSNT SUPPORT 1GB CARD INSTEAD OF USING 1GB CARD PUT 512MB OF MEMORYCARD AND UPDATE YOUR MOBILE SOFTWARE
5answers
Sony Ericssin Z550i Picture corrupted & MP3 failed to play.
There could be a problem with your memory card. Back up everything and reformat the card.
8helpful
7answers
Sony ericsson w200i mp3 playback problem
I was facing the exact same problem with my W200i. I formatted my memory card using the "Quick Format " option and then re-uploaded my songs. That solved my problem. There is no disturbance in between songs now, also the "Playback Failed" error has also not occurred again.
3helpful
8answers
W200I software problem
seems it cant find the file...
in walkman press back key and then scroll dwn to Tracks...
if ur file is listed here then play it frm here... if it isnt in Tracks list, u'll need to upload the file frm pc 2 mobile again...
The walkman malfunctioned!!! please help!!!
Hi there, one of the problems you have is that there is not much you can access from via your phone, so often the easiest (although not speediest) solution is to re-upload the songs. Have you tried adding another song, playing it, and seeing if that song will play successfully? If it does, then I would suggest deleting the other songs, and uploading them to your phone again. If this is not possible (because you downloaded them straight from mobile network), upload them to a PC and see if the songs will play - if they do, save them to PC, reformat your card (my computer -> right click on card name -> format) and then put them back on your phone. Unfortunately if they wont play on PC either, the chances are they have been corrupted and you may have to contact your download source for a refund or new copies. If after trying these options you are still stuck, try a) a mates memory card in your phone, and b) your memory card in a mates phone. If a works and b doesnt, contact your memory card supplier. If b works and a doesnt, then contact your phone manufacturer. Hope this helps and isnt too confusing - Chris.
Top Sony Ericsson Cell Phones Experts
Sean Wright
Sean Wright
Kolbrun...
ZJ Limited
ZJ Limited
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
