In my laptop a message is showing " you just plugged a device on to the audio jack" and then laptop speakers will not work after showing this message this is happening frequntly in my laptop if any body have solution please inform
That "no audio devices are installed" message does not refer to the headphones, but to the sound chip in the laptop. Your operating system is not seeing the laptop's audio chip, which is built into the laptop's motherboard. This could be due to a hardware failure, or a software problem (corruption of the audio chip's driver). To tell which of these is the problem, open "Device Manager" and look for any device that may be highlighted with an exclamation mark. If anything that resembles an audio device is so marked, it means the operating system is able to see the audio chip. and you problably don't have (total) audio hardware failure. You have to search, download and install the driver for this "problem" device. If no audio device is seen at all, then there is probably a hardware fault with the motherboard/audio chip. All is not lost. You can buy an inexpensive USB audio dongle that will allow you to route sound out from the laptop into external speakers or headphones. However, you'll lose the use of the internal laptop speakers that were dependent on the internal audio device (chip).
Reboot the computer. Is it connected to the headphones jack? Check the plug. Open the sound device, select the headphones.Open the Device Manager , check the audio is enabled. Re-install the driver for the audio.
I find that there is a problem with your headphone speaker. Try with some other headphone, even if it is not working, then you need to take it to the service center.
go to control panel-sound-default audio device & check which device is enabled as default device. In case of HD audio remove the speaker jack & reinsert, if that port is selected as default audio then you should get an immediate message saying 'audio jack plugged in'.
go to the control pannel, then go to sounds and audio devices, then click the audio tab across the top. under sound playback, choose your speakers as the default device. solution only works like this for windows xp. good luck
You might have to reinstall the software that came with the speakers since you had to wipe your computer clean when the virus was on there. The speakers will not work until the software is installed back on your computer.
