SOURCE: LG REfrigerator - water line connector
Try closing the water valve slightly to reduce the water pressure to the unit.
Sgt 48
SOURCE: LG ice maker only making two ice cubes at a time
Colenoid in the ice dispenser may be clogged or have a small amount of trash in it. Is there a filter on before the fridge (just after the ice maker shutoff)?
SOURCE: Ice Maker Freezing Up and Ice not dispensing
Check your ice cube tray to see if it is warped. Mine was. I took the tray off and dipped it into boiling water and remoulded it to the original shape and re-installed it. So far no problems. The tray gets warped because of the ice cube release mechanism. The tray is rotated around until it meets a block on one corner which creates the twisting motion we used to do on manual trays. Over time it tends to warp the tray. Good luck
SOURCE: LG French Door Model LFX 25960--Freezing in right crisper door
Have person who changed out you controlboard come back and recheck connections and controlboard itself.
SOURCE: lg refrigerator LFX25960SW
I work on LG/Kenmore elite "Trio"aka french door model about 3 times a day on all kinds of problems. Read through this for both Icemaker freezing and crisper bins freezing. First, the Icemaker freezing problem could be either water valve is not closing properly causing too much water to get to Icemaker or the liner on the roof of the Freezer section is sagging. There is a fix and that would be a liner kit from LG. Second, the problem on the bottom crisper bin freezing is an issue with the bottom liner under the bin is bubbling. If you can take the tray out and push the liner up and down like a pillow, it has separated and it is holding freezer temp air in there causing the left side to freeze. THERE IS NO FIX TO THIS YOU MUST NOT PUT SCREWS INTO IT, IT CAN POSSIBLY DAMAGE WHAT IS UNDER THE LINER CONSULT LG OR THE MANUFACTURER ON THIS PROBLEM!!!!!!!!!
REMEMBER THIS IS FROM A RESPECTABLE REFRIGERATOR TECHNICIAN, NOT A MOM/POPS COMPANY....
